milto29 Posted May 5, 2013 Report Share Posted May 5, 2013 Hey guys , can you Downshift with a Lock Up Clutch? I was told that anything over 85hp I would need a Lock Up Clutch. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted May 5, 2013 Report Share Posted May 5, 2013 you can down shift over rides trans are what you dont down shift with Quote Link to comment Share on other sites More sharing options...
milto29 Posted May 5, 2013 Author Report Share Posted May 5, 2013 you can down shift over rides trans are what you dont down shift with Thanks buddy ! I do lots of Trail Riding down here. Would you recommend it ? (Lock Up Clutch) I'm almost done with one of my bikes. If all goes well I should be around 80hp to 85hp. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted May 5, 2013 Report Share Posted May 5, 2013 after about 70hp, shifting under power a stock trans with or with out a lockup isnt going to happen. ive got a got a driveline lockup on my 55hp stockish bike. makes the clutches last forever Quote Link to comment Share on other sites More sharing options...
milto29 Posted May 5, 2013 Author Report Share Posted May 5, 2013 after about 70hp, shifting under power a stock trans with or with out a lockup isnt going to happen. ive got a got a driveline lockup on my 55hp stockish bike. makes the clutches last forever So what would you recommend with my setup? I mostly Trail Ride im really not into Drag Racing. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted May 5, 2013 Report Share Posted May 5, 2013 you got a 85hp motor but not into dragging? your going to need some clutch upgrades, wheather its a lockup, or a combo of better fibers/steels, stiffer springs, or even a 8 plate clutch or the stock 7 plate. Quote Link to comment Share on other sites More sharing options...
milto29 Posted May 5, 2013 Author Report Share Posted May 5, 2013 you got a 85hp motor but not into dragging? your going to need some clutch upgrades, wheather its a lockup, or a combo of better fibers/steels, stiffer springs, or even a 8 plate clutch or the stock 7 plate. Lots of Torque buddy. I currently have on now a Tusk HD setup. I need the power to get out of these tight turns. Ill post some videos later once I get my Go Pro and you'll see what I'm talking about. I have a Regular Stand Up Banshee with crazy power off course. Every once and a while we will line it up with the buddys. But thats not the route I'm going for. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted May 5, 2013 Report Share Posted May 5, 2013 it sounds like you need a modded trans like a dunable over ride, or have every other cog removed from the gears and a lock up Quote Link to comment Share on other sites More sharing options...
milto29 Posted May 5, 2013 Author Report Share Posted May 5, 2013 it sounds like you need a modded trans like a dunable over ride, or have every other cog removed from the gears and a lock up Do you know of anybody that does that ? Quote Link to comment Share on other sites More sharing options...
Nightmare Posted May 5, 2013 Report Share Posted May 5, 2013 Trail riding with 85hp? I like you're style:D<br /><br />Sent from my SGH-T679 using Tapatalk 2<br /><br /> Quote Link to comment Share on other sites More sharing options...
milto29 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Trail riding with 85hp? I like you're style:D<br /><br />Sent from my SGH-T679 using Tapatalk 2<br /><br /> Thats nothing theres a buddy in the group with a Raptor 700 93hp Trail Riding . Popping wheelies on 6th gear. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted May 6, 2013 Report Share Posted May 6, 2013 Thats nothing theres a buddy in the group with a Raptor 700 93hp Trail Riding . Popping wheelies on 6th gear. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted May 6, 2013 Report Share Posted May 6, 2013 Camatv does stock trans mods. Lockup clutches allow the fibers to be clamped together harder as rpm increases. Over-ride Trans's are meant for drag racing (however there are a few people who run a dunable over-ride in trails which is slightly more forgiving) the reason being is that you can shift while under full load of the motor....without clutching. However there is one thing that is not a good idea with it.....and that is back-loading. Back-loading is when you downshift and release the clutch to allow the motor to assist in braking. Also called dynamic braking. There are 2 possibilities when it comes to a lockup. One being a direct drive style and one being a gigot slingshot. The direct drive style uses bolts/nuts as weights and uses rotating speed to pull the arms up and press harder on the clutch pack. The weights are changed by replacing the bolts/nuts. The gigot slingshot mounts under your stock cover (sometimes a little grinding of some nubs is required) and uses ball bearings to set the strength of the pressure on the clutch pack. To ease the pressure, just remove one of the 2 balls per slot. if that's still too much you can remove all the ball bearings from EVERY OTHER slot. Very adjustable. Hope the info has helped. Jereme Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted May 6, 2013 Report Share Posted May 6, 2013 Wcr promod tranny with fast clutch. I have ported serval and can power shift all day. Smoothest tranny there is. Probably similar to cams modded tranny. You do not need an override or lockup Quote Link to comment Share on other sites More sharing options...
