highcomp26 Posted May 5, 2013 Report Share Posted May 5, 2013 This should simple as 123 all I did was swap my clutch lever and now it seem like if I put the bike in gear when its off and I pull in the clutch its not neutralizing the bike. The adjustment is all the way out, the cable is in on both ends. Any help would be appreciated Quote Link to comment Share on other sites More sharing options...
m671054 Posted May 5, 2013 Report Share Posted May 5, 2013 Either to much freeplay or the lever design has less travel Quote Link to comment Share on other sites More sharing options...
highcomp26 Posted May 5, 2013 Author Report Share Posted May 5, 2013 So whats the fix for this, how do I know its the wrong lever if I get another. I got it from Yamaha so I assumed it was the correct one I got. Quote Link to comment Share on other sites More sharing options...
m671054 Posted May 5, 2013 Report Share Posted May 5, 2013 Is it the same stock lever? or a replacement with no pbrake Quote Link to comment Share on other sites More sharing options...
highcomp26 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Replacement with no p brake Quote Link to comment Share on other sites More sharing options...
m671054 Posted May 6, 2013 Report Share Posted May 6, 2013 Not sure what stock throw is. maybe someone will chime in with what lever/perch combo works good. are you sure your free play is good Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 6, 2013 Report Share Posted May 6, 2013 You may need to adjust it at the pressure plate. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 6, 2013 Report Share Posted May 6, 2013 A buddy of mine had the same problem with a universal lever/perch. Try adjusting the arrow on the case a 1/4" to the stator side at the pressure plate first. Quote Link to comment Share on other sites More sharing options...
