Axle and Hubs.
Yes Honda Yamaha are the same I had a set of each for my kfx700 so me and my Buddy's could all swap tires. Also you may run into spacer problems one if them I can't remember witch needs a spacer for the nut yo tight in up on the kfx but it may not be a problem on the banshee
The issue is putting Honda on Yamaha. (That requires some very thin additional spacers that were easily made by stacking thin washers I found at Ace Hardware.) But if your going to put Yamaha hubs on a Honda......No problem.
Just called a friend whom has a set laying around and is giving them to me for FREEEEEEE hell ya! Thanks againg guys for your help. soon ill be posting picks of my build in the correct forum of course!!!
SCORE!  :headbang:  If you can buy your way out of a problem....then you don't have a problem.
If you have friends handing you parts you need and a wallet isn't even involved........then your in the right place at the right time with the right friends.
5 1/2 hours from problem to solution. Not a bad day.  :clap:
  • 2 weeks later...
