Decline0556 Posted May 2, 2013 Report Share Posted May 2, 2013 Ok I have a 2000 model banshee was starting up fine but didn't really have any power so we got to looking and it didn't have an idle pin on one of the carbs so I got the pin we put it in and adjusted carbs , and it ran for a second and then it died and won't start back up?! Iv checked and it has fuel and spark what can be the problem here? We've messed with it for days checking everything even took carbs apart and cleaned them any info would be much appreciated ! Quote Link to comment Share on other sites More sharing options...
toytech Posted May 2, 2013 Report Share Posted May 2, 2013 is the tors removed? check compression, new or old fuel. did you pull the jets out to clean or just spray them? is the choke tube in place? are the slides in correctly? welcome to bhq Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted May 2, 2013 Report Share Posted May 2, 2013 ^^^ slide's might be adjusted too high. i did it to mine when i did a rebuild and whouldnt start for shit. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 3, 2013 Report Share Posted May 3, 2013 Read through this: http://www.dfn.com/agservices/jetfaq.html Quote Link to comment Share on other sites More sharing options...
J-Madd Posted May 3, 2013 Report Share Posted May 3, 2013 Choke tube Quote Link to comment Share on other sites More sharing options...
Decline0556 Posted May 3, 2013 Author Report Share Posted May 3, 2013 Thanks for all the replies everyone really appreciate it will defiantly check on some of the things you brought up this weekend. I may just have to give in and take it in to a shop if its still not working Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 3, 2013 Report Share Posted May 3, 2013 Get a flow meter: http://www.ebay.com/itm/170988649606?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 3, 2013 Report Share Posted May 3, 2013 How to use it and adjust: Quote Link to comment Share on other sites More sharing options...
