Drturbodiesel Posted May 2, 2013 Report Share Posted May 2, 2013 Ever since I had my banshee (3 years now) it has smoked more from right side. Before I rebuilt it I figured it was because it was the weak side as far as compression goes. After rebuild it still did and now have added pipes jets and reeds filter etc. still does. It's runs great always has but it drives me crazy for that much more smoke on right side. Never used a drop of transmission oil by the way Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted May 2, 2013 Report Share Posted May 2, 2013 Did you make sure you put gas in the left side gas tank? Sync your carbs and try again. Check for air leaks on the left side, especially since you just did a rebuild. Quote Link to comment Share on other sites More sharing options...
Drturbodiesel Posted May 2, 2013 Author Report Share Posted May 2, 2013 It's strange it's like the closer I get carbs in sync the worse the problem becomes. Will check for air leaks on opposite side tho. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted May 2, 2013 Report Share Posted May 2, 2013 It's strange it's like the closer I get carbs in sync the worse the problem becomes. Will check for air leaks on opposite side tho. Well the carbs should be dead on Get them perfect, then start chasing other problems. Build a leak down tester and see if there's an air leak. Have you switched your plug wires from side to side to see if it changes sides? Quote Link to comment Share on other sites More sharing options...
Drturbodiesel Posted May 2, 2013 Author Report Share Posted May 2, 2013 No I haven't yet. Just got new caps but it was just so they would match. One was stock one Honda Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 2, 2013 Report Share Posted May 2, 2013 It's strange it's like the closer I get carbs in sync the worse the problem becomes. Will check for air leaks on opposite side tho. Did you replace your pilots? Quote Link to comment Share on other sites More sharing options...
Drturbodiesel Posted May 2, 2013 Author Report Share Posted May 2, 2013 Yea one step up for fattys. Come to think of it my stator side got a lot of water because a dirt dobber nest stopped my vent hole tho motor and when I washed it water ran down tho into stator cover and rusted all that pretty good. Bet that rutted my crank seal and I dread splitting cases Quote Link to comment Share on other sites More sharing options...
Drturbodiesel Posted May 2, 2013 Author Report Share Posted May 2, 2013 I read on a older post that I can take engine off and side covers and only take bottom half of case up to install crank seals and leave cylinders together Does anybody know if that's possible? Quote Link to comment Share on other sites More sharing options...
blue97shee Posted May 2, 2013 Report Share Posted May 2, 2013 Its possible, but its honestly easier to just do it the right way. pull the jugs off, the cases split top to bottom. all the parts stay in the bottom case, couldnt be any easier. Quote Link to comment Share on other sites More sharing options...
