10mil Titan Cub (Price Dropped)
10mil cub ported by Tim @ Titan Racing.  Dyno'd at 109hp @ 7200ft elevation with 35.5mm carbs and 6 or 7deg of timing.  It dyno'd at 120hp in las vegas with 39mm carbs and 7deg of timing.  It has a very nice flat curve all the way across the top.  I'm willing to deliver within a reasonable distance for a price.  (Pics at bottom of post.)  Bike has always been kept under a cover and inside my shop since I've had it.
$6500
Title In-Hand
K&T / Racers Edge Chrome Drag pipes
10mil forged crank w/ maxload bearings on both ends
10mil Polished cub ported by Tim @ Titan Racing
Custom cut domes by Tim @ Titan Racing
Polished Cool Head
VForce 2 Reeds
Billet intakes
35.5mm Methanol Mikuni Carbs set up by K&T w/ mikuni 35Lph pump & Billet filter adaptor.
Chariot Billet Bowls
K&N Pod Filters
Chariot outboard bearing support
Billet water pump
Hinson Straight-Cut Gears & spring-loaded 8-plate billet basket
Hinson 8-plate Inner Clutch Hub
Hinson Pressure-Plate
Direct-Drive lockup & Cover
1-4m5,6 override
Stock flywheel
Adjustable timing plate
Metal Tech +4 forward frame
Metal Tech Chrome +14 crushed oval swingarm
ModQuad drilled 40mm drag axle
LSR +2+1 Chrome A-Arms
Works Dual-Rate front shocks
Marvin Shaw rear shock
Lew Swan custom painted fiberglass fender w/ matching rear
Aluminum Drag Tank
Metal Tech chrome steering stem
Billet tie-rods
22x11x8 SLS 13-paddle haulers on douglas blue-label rims
21x7x10 mowhawk front tires on douglas blue-label rims
chrome foot-pegs
Chrome fasteners
Braided stainless steel rear brake line
ASV clutch lever
Chrome rear brake lever
Billet parking brake block-off plate
Custom seat cover by vegasjeff
Moose billet thumb-throttle housing w/ billet thumb-throttle lever
ODI Grips
