smurph317 Posted April 29, 2013 Report Share Posted April 29, 2013 I took my banshee engine apart to replace shifting forks . Which turned into all new shifting hardware , trans. Shaft , new crank etc. I want to put a new set of rings on my pistons while its apart . The problem is I can't tell what brand of pistons I have . I cleaned them up and don't see anything on them . There is a number in the top of the piston looks like 2.25 .. I orderd a set of Wisco ring but there way to thin to fit my ring land . The rings on my piston are twice as thick .. I have no idea how to determine what brand of rings to order . ? The numbers on top of the pistons mean anything ? My bore now is 66mm . Quote Link to comment Share on other sites More sharing options...
coryv4 Posted April 29, 2013 Report Share Posted April 29, 2013 is there a stamped letter on it? pull the pison off and look in side some have numbers inside Quote Link to comment Share on other sites More sharing options...
smurph317 Posted April 29, 2013 Author Report Share Posted April 29, 2013 I had them off and didn't see anything inside either . I think there may have been a single letter inside . But nothing else Quote Link to comment Share on other sites More sharing options...
BB3 Posted April 29, 2013 Report Share Posted April 29, 2013 post up a picture of them it may help determine what you have. Quote Link to comment Share on other sites More sharing options...
smurph317 Posted April 29, 2013 Author Report Share Posted April 29, 2013 I am trying to upload pictures but it says file too big to upload . Is there an easier way ? Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted April 29, 2013 Report Share Posted April 29, 2013 get some new pistons might as well.... Quote Link to comment Share on other sites More sharing options...
smurph317 Posted April 29, 2013 Author Report Share Posted April 29, 2013 Lol that's not what i was looking for Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted April 30, 2013 Report Share Posted April 30, 2013 u need to get some one to check the cylinders and pistons out to make sure eveything is the right size. u have already replaced the stuff in the botom side. so u might as well get the topside checked. u might need a bore or atleast a hone and probley new pistons. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted April 30, 2013 Report Share Posted April 30, 2013 If it really is 2.25 stamped in the top, that could mean 2.25mm oversize which would be 66.25. 66.00 is considered the last safe bore. After that, the cylinder liner gets pretty thin and can break off at the bottom. Regardless of whether you are at 66.00 or 66.25, those cylinders are at the end of their life. Don't spend a bunch of money on them. Quote Link to comment Share on other sites More sharing options...
Nieskes Posted May 2, 2013 Report Share Posted May 2, 2013 Goto the store and get a caliper. Measure the bore and report back. Quote Link to comment Share on other sites More sharing options...
