are beadlocks necessary?
My bike with bead locks
My bike without bead locks
20-11-9 tire and wheel size
Those are the tech3 bead locks, the only thing that I have had a problem with is they didn't want to seal without using bead sealer on them... And if you tighten the rings over 11-12 ft lbs they don't want to seal right. And remember when you put the rings on, tighten them in a circular motion, NOT a cross pattern
Where did you have to out bead sealer at? I've had jacked up bead tired mounted up in mine quite a bit and never had an issue sealin up. Never noticed any difference in how I tightened the ring either?
