blk01hd Posted April 27, 2013 Report Share Posted April 27, 2013 i have a dirt digger clutch with race springs in my banshee and i cant keep clutch cables on it. the engine side end keeps shearing off every 3 months and ive tried every brand of cable from local dealers and online too. so can anyone point me in the right direction of and good strong cable thanks in advance. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 27, 2013 Report Share Posted April 27, 2013 i have a dirt digger clutch with race springs in my banshee and i cant keep clutch cables on it. the engine side end keeps shearing off every 3 months and ive tried every brand of cable from local dealers and online too. so can anyone point me in the right direction of and good strong cable thanks in advance. Either a factory cable or a Motion Pro should work fine. If you are tearing those up you need to inspect your clutch system. Make sure the actuator arm and its bearing are in good shape, the pushrod and ball slide freely inside the mainshaft,do you have more spring than you really need? Do you have a lockup plate in it? Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 27, 2013 Report Share Posted April 27, 2013 And use graphite spray to lube cable, works amazing Quote Link to comment Share on other sites More sharing options...
Starwriter Posted April 28, 2013 Report Share Posted April 28, 2013 Is the thingy that the clutch cable goes into rusted up so that it doesn't pivot on the actuater arm? If so, it's flexing the end of the cable side to side every time you pull the clutch lever. Quote Link to comment Share on other sites More sharing options...
blk01hd Posted April 28, 2013 Author Report Share Posted April 28, 2013 everything seems to be okay dont wanna tear apart the check ball and shaft. lock up plate? i used the race springs so that way i know the clutch will grab when clutch is released. thanks for input Quote Link to comment Share on other sites More sharing options...
