RadarRacing Posted April 24, 2013 Report Share Posted April 24, 2013 The slingshot is the best. It will hold even huge HP without much weight and yes it replaces the pressure plate on some models. I would call gogot Performance direct and ask Kevin. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted April 24, 2013 Report Share Posted April 24, 2013 Oops I meant Gigot Performance. The slingshot works and releases really well with an easy clutch pull. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 25, 2013 Report Share Posted April 25, 2013 What type of lockup would you recommend for a fairly strong trailbike? Vito's undercover. Been running mine for 3+ years on my 4mil till the day she died. Coolest part is no one knows you have it. I run extra weight and 3hd/3stock springs. Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 25, 2013 Report Share Posted April 25, 2013 Well i wanna get a lockup cover anyways just because mine is all gashed up and i want to be able to access my clutch alot easier anyways, ill contact gigot when i wanna get one. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 25, 2013 Report Share Posted April 25, 2013 Then get an aftermarket cover.... Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted April 25, 2013 Report Share Posted April 25, 2013 I was under the impression that if you had a stock tranny that a lockup would make it much harder to run through the gears under load??? ??? Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 25, 2013 Report Share Posted April 25, 2013 I read that many times too. But i have a dune able over ride. No worries here Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted April 26, 2013 Report Share Posted April 26, 2013 I read that many times too. But i have a dune able over ride. No worries here That's no help!!! Lol Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 26, 2013 Report Share Posted April 26, 2013 Really? so say i have a slingshot lockup then i probably wouldnt be able to speed shift anymore that what your saying? As of now i can hold my bike wide open and fan through gears without letting off and its smooth as butter with a modded star and shift detent bearing. Quote Link to comment Share on other sites More sharing options...
