stock carb idling problem
Ok so I have lrd adjustable pipes, +5 timing, vf2's, cool head 20cc domes, mild port, stock carbs tors delete with uni pods. Switching to a airbox with k&n's soon. Elevation is 88ft above sea. 65 degrees had 25 pilots and 300 mains. It idled fine but would hang when gas was tapped. So I switched to a 27.5 and the hanging stoped but it won't idle. At the moment idle screws are all the way in and mixture screws 2 turns out. Carbs are clean and synced. Any ideas.
did you grind enough off the carbs for the idle screws to raise the slides enough? also make sure the choke tube is tight on the carbs.
x2 look in your carbs and see if the idle screw moves the slide when you adjust it. If the slides don't move when the screw is turned in all the way you need to take some more off the carb body(outside)
