thomas h. Posted April 22, 2013 Report Share Posted April 22, 2013 Seems like if I don't use it for 2 months it need alittle spray to get it going. Why and is their a fix. Stock motor t5 and k&n Good plugs and caps Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted April 22, 2013 Report Share Posted April 22, 2013 What pilots? sounds just a little lean. Or it may just be the shitty gas with all the ethanol in it. It seems to not keep very long. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted April 22, 2013 Author Report Share Posted April 22, 2013 25 p 300m Stock needles So maybe screw in the mix screws Btw choke on doesn't help New motor too Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted April 22, 2013 Report Share Posted April 22, 2013 I've always ran 27.5 pilots. If all the way in on the air screw ( half turn out) doesn't help it. I'd try bigger pilots Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 22, 2013 Report Share Posted April 22, 2013 X2 on the Ethanol, Don't buy gas from a grocery store or convenience store, Ask for pure gasoline. Goggle the negative effects of Ethanol, you will be amazed. I run 25 pilots with T5's and K&N. with 3 kick starts after sitting for over 4 months. I plan to try 27.5 though. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted April 22, 2013 Report Share Posted April 22, 2013 X2 on the Ethanol, Don't buy gas from a grocery store or convenience store, Ask for pure gasoline. Goggle the negative effects of Ethanol, you will be amazed. I run 25 pilots with T5's and K&N. with 3 kick starts after sitting for over 4 months. I plan to try 27.5 though. You can't buy pure assoline here. Juzt the 10%. I also agree with 27.5's. I had similar mods and ran 27.5's and 320's, but I always liked my shit to run rich. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 22, 2013 Report Share Posted April 22, 2013 You can't buy pure assoline here. Juzt the 10%. Man, that just sucks. That crap does go bad in 30 days,and separate,and varnish shit up. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted April 22, 2013 Report Share Posted April 22, 2013 Man, that just sucks. That crap does go bad in 30 days,and separate,and varnish shit up. Really? I've left shit in cars for 6 months or more with no issues. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 22, 2013 Report Share Posted April 22, 2013 One dune trip, my 3 four strokes popped lean on the top end, my 2 strokes had noticeable increase in EGT and completely burned out packing,and my fuel station on my toy hauler pumped 5 gal then the very next day pumped 10 drops and seized up, pulled the pump head apart to find a thick amber goo. On retrospect, that was all Casey's Conveniece store premium and I'm not to sure they stick to the 10% max. but really, Goggle it, the 2 stroke boat mechanics blame it for everything. Quote Link to comment Share on other sites More sharing options...
joey83 Posted April 22, 2013 Report Share Posted April 22, 2013 Mine does that. I think it's the choke rubbers bc when I pull the choke while its running and warm, it doesnt hardly effect it. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 22, 2013 Report Share Posted April 22, 2013 Of coarse it will run leaner on a 10% mix than pure gasoline. If you jet it for the 10% mix, you have nothing to worry about. understood, but it will still evaporate in the carbs and clog shit faster. Quote Link to comment Share on other sites More sharing options...
Finch Posted April 22, 2013 Report Share Posted April 22, 2013 i may just be anal but i only mix what im gonna use that weekend and what ever is left goes in the truck or lawnmower Quote Link to comment Share on other sites More sharing options...
Nightmare Posted April 22, 2013 Report Share Posted April 22, 2013 i may just be anal but i only mix what im gonna use that weekend and what ever is left goes in the truck or lawnmower X2, I've let a lot of gas go to waste by letting it sit. Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
thomas h. Posted April 22, 2013 Author Report Share Posted April 22, 2013 Well I guess I can drain the carbs next time to prove the theory. I was planing on switching to alba needles and bigger pilots 300 mains. Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted April 22, 2013 Report Share Posted April 22, 2013 Just drain the bowls and let a little fresh gas run out too. Close it up and kick it, that usually works for me in the spring. Quote Link to comment Share on other sites More sharing options...
