Still no spark?
Ok guys, here is what Ive done so far:
Resistance from stator to CDI:  18.1 ohms.
Not sure if this is correct:  .5 Ohms to Coil? (How do you check the coil?)
I checked my tether switch, kill switch, the ground by the coil, and the ground at the voltage regulator.  Coil itself is grounded to bare metal on the frame and so is the CDI.  AM I missing a ground somewhere else?  I put a new timing plate on it and put the stator on exactly as it came off the stock one.  I did find that the rubber around the orange wire from the CDI to the Coil has rubbed off (little spot).  Could that be the problem.  I am a complete retard when it comes to electrical stuff.  Oh yeah, and ive quadruple checked the grounds that I know of.  If Im missing one, fill me in!
Coil test is primary side(black wire terminal to orange wire terminal) is supposed to be like 0.28-0.38 ohms I believe and secondary side(plug wire side) one lead on plug wire side and one lead on corresponding primary side and should get 47k ohms or higher I can remember what the high side limit is. Also check your plug.wires and boots.
Unplug the cdi. Test at the cdi connection so you test all the wiring between the cdi and the components.
Red to green: 13.5-20.5
White/green to white/red: 95-140
black to orange: 0.28-0.38
spark plug boot to spark plug boot: 5700-8100 (4700-7100 + 2 5k plug caps)
Red/black to black: short (with key switch turned on)
Black/white to black: open (with kill switch turned on)
