joewest Posted April 16, 2013 Report Share Posted April 16, 2013 I have a compression tester. Can't screw it in tho. Would I need to just remove my tank? Or is there a different one that works better with quads? I've also heard people say to hold the throttle wide open when kicking it. How many times should I kick it? Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted April 16, 2013 Report Share Posted April 16, 2013 Do as you said, hold throttle open and kick until the needle stops moving. Make sure the threaded part on the comp tester is Exactly the same length threads as the spark plug or your reading will be off. You can screw it in with the tank on if the hose is bendy, a bit tricky though. But much easier with it off as the head is looking right at you. I always check both sides 3 times to make sure its reading right. Very simple. What gauge are you using? Quote Link to comment Share on other sites More sharing options...
joewest Posted April 16, 2013 Author Report Share Posted April 16, 2013 Its a gauge used for cars I dunno what brand. I tried to screw it in with the tank on and I can't get it in. Bike runs good and all just wondering what the compression is at. Thanks Quote Link to comment Share on other sites More sharing options...
Finch Posted April 16, 2013 Report Share Posted April 16, 2013 usually if i spit on it it goes right in Quote Link to comment Share on other sites More sharing options...
Dalton Posted April 16, 2013 Report Share Posted April 16, 2013 I use a Snap On motorcycle compression tester. I can do the testing with the tank on. Wide open throttle. ..kick until the needle stops...usually 20 or more kicks. Quote Link to comment Share on other sites More sharing options...
joewest Posted April 16, 2013 Author Report Share Posted April 16, 2013 OK cool I'll prob get one of those then. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 17, 2013 Report Share Posted April 17, 2013 usually if i spit on it it goes right in My brother taught me that back in high school. Been using that method on everything from pussy to cabinetry. Quote Link to comment Share on other sites More sharing options...
Chris327 Posted April 19, 2013 Report Share Posted April 19, 2013 you should check ebay for one designed for an atv... there not too expensive Quote Link to comment Share on other sites More sharing options...
mike0chek Posted April 19, 2013 Report Share Posted April 19, 2013 My brother taught me that back in high school. Been using that method on everything from pussy to cabinetry. LMAO! Quote Link to comment Share on other sites More sharing options...
