LowlyOilBurner Posted April 16, 2013 Author Report Share Posted April 16, 2013 Here's a couple more pics: So if this is indeed a no link arm, what are my options for a rear shock? Marvin Shaw hill shooter? Elka? The bike is mostly used on relatively smooth fire roads. Thanks for the input! Quote Link to comment Share on other sites More sharing options...
Starwriter Posted April 16, 2013 Report Share Posted April 16, 2013 Definitely not a no link swinger. Like I mentioned in my correction post, if it were, it would be sitting too low. Tie a string around the axle. Stretch it out to the pivot bolt. Adjust it at the axle with tape, sticks, whatever, so that it's centered with the big roundhouse tube. Measure from the string upward to the swinger link bolt hole. If it's made right, it should be 1 1/2". I bet yours is a LOT more than that. If so, bitch at the people that made it. Quote Link to comment Share on other sites More sharing options...
LowlyOilBurner Posted April 16, 2013 Author Report Share Posted April 16, 2013 I contacted East Coast ATV today, and explained the situation. They told me they have installed this same swinger on a few other shee's and it does raise the rear up a bit... They are sending me a "lowering link". I guess if it can drop it a few inches, I can live with that... Quote Link to comment Share on other sites More sharing options...
Starwriter Posted April 17, 2013 Report Share Posted April 17, 2013 That's a band aid fix for an improperly designed swingarm. I wonder what that does to the suspension geometry. I would tell them to fuck off, and get your money back + your paint expenses. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 17, 2013 Report Share Posted April 17, 2013 That's a band aid fix for an improperly designed swingarm. I wonder what that does to the suspension geometry. I would tell them to fuck off, and get your money back + your paint expenses. Hell yeah. People need to let these shops/distributors/builders that there not happy. It's not what you want. Your suspension is fucked up. You want it right, not a lowering link to fix the swingarm fuck up. Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted April 17, 2013 Report Share Posted April 17, 2013 Not that it matters, but how come you're running a +6 on what looks like a stockish bike? Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted April 17, 2013 Report Share Posted April 17, 2013 Nevermind. See what looks like a cub. I'll shut up. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 17, 2013 Report Share Posted April 17, 2013 Nevermind. See what looks like a cub. I'll shut up. Put your glasses on gramps. Quote Link to comment Share on other sites More sharing options...
possum Posted April 17, 2013 Report Share Posted April 17, 2013 Looks like the mount tabs are about 1"- 1-1/2" to high. I bet putting the bolt hole below the lower swingarm tube will be just right. I have never seen a mounting point that high above the chain as well. You can add a warrior link or lowering link. Also a +6 will always raise the rear. Its just even more with the arched swinger that has mounts that are a lil high. I like to lower the mounting point to lower the bike with longer arms and move the mounting point back 1-2" depending on the setup, to help sag. Quote Link to comment Share on other sites More sharing options...
LowlyOilBurner Posted April 17, 2013 Author Report Share Posted April 17, 2013 It's a 485 cheetah. Nothing crazy, it pretty much is a stock bike, that's why I got this swingarm, I'm starting to replace all the stock suspension piece by piece. Yeah, it does seem like a bandaid fix... I'll call them again today. I don't know if they can do much, shit, the thing has been powder coated, greased, bearings pressed in, it's "used" essentially. It wasn't cheap either... Quote Link to comment Share on other sites More sharing options...
Starwriter Posted April 17, 2013 Report Share Posted April 17, 2013 You are being way too nice. I certainly wouldn't trust my life to someone that can't even get the shock mount in the right position. The fact that you had to grind the bolt head to get it to fit through between the tubes, shows right there that they haven't put a lot of thought into their design. This isn't a simple, "oops, we made a mistake, sorry". The fact that Eastcoast admits that this swingarm raises it up "a bit", shows that no one is willing to take responsibility. Jam that thing up their ass. Quote Link to comment Share on other sites More sharing options...
87sheerips Posted April 19, 2013 Report Share Posted April 19, 2013 If you are using that bike primarily for trails, I would ditch the arch setup and get a traight, round tube, heavy duty setup from say Wheelman or Stellar or turbo chassis..... The arch should be used on sand only IMO. Quote Link to comment Share on other sites More sharing options...
LowlyOilBurner Posted April 19, 2013 Author Report Share Posted April 19, 2013 I sent it back to the manufacturer, they are either fixing it or building a new one. I will see how it ends up, I may end up getting something different. Quote Link to comment Share on other sites More sharing options...
