Need Help! On 421 Cheetah Cub Build
What kind of riding are you doin? A cub is setup for drag racing out of the box so you wont have much bottom end on it..
What pipes have you got?
Start here by stating your goals for the banshee, maybe we have an insight your friend doesnt have
i do mostly trail riding and lil drag races to play around i have pro circuit factory 304's that i wanna get rid of so i can get some cpi's shearer's or Rocket r2 in fames. im looking for the mid range to top end power and i wanna run it off of pump gas with the option to run race gas
if you are mainly trail riding and want to run pump fuel, but still want power and mid-top end......id suggest a serval.  They make really strong power all throughout the powerband, and with the cool head, you could swap domes to increase your compression to run race fuels......although I don't see the power being worth that much hassle.
Gonna warn you though....depending on what you have now on your bike.....your going to be needing the supporting mods.  So unless you have 2k+ set aside to throw at a motor.....keep saving.  Its not just the top end, but the supporting mods.... clutch, pipes, carbs, pancake bearing, clutch lever, filters, intakes........it adds up QUICK.
  • Like 1
