Justintoxicated Posted October 23, 2003 Report Share Posted October 23, 2003 I fergot what tool I needed to adjust my timing plate...It's a flywheel puller right?? And if so is this an easy thing to adjust myself without an air compressor or special wrench? How do I know how much to tighten the nut back up? I want to advance my timing 4 degrees, and I have an adjustable plate already. Thanks. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted October 24, 2003 Report Share Posted October 24, 2003 On my son 2003 with a ricky stator plate he can adjust it with flywheel still on and a open end 10mm . there is room. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted October 24, 2003 Author Report Share Posted October 24, 2003 On my son 2003 with a ricky stator plate he can adjust it with flywheel still on and a open end 10mm . there is room. Yea thats odd, I called ricky stator and he told me I would have to remove the flywheel. Even if I can leave it on do I still need the puller? They said they didn't have enough time tomarrow to torque the nut off for me, and I would have to wait till next week and maybe they can do it for me...But I can't wait and wait on sch a little thing to be done. Im going to buy a puller tomarrow unless I REALY don't need one yet. Cause $15 for the puller is 3 days lunch here! Quote Link to comment Share on other sites More sharing options...
SDD Posted October 24, 2003 Report Share Posted October 24, 2003 Don't worry about a puller if your going to have your crank welded. You'll have to remove the flywheel if your going to send out the crank. Check your PM and let me know if you want it done. Quote Link to comment Share on other sites More sharing options...
Hiram Posted October 24, 2003 Report Share Posted October 24, 2003 Once installed it can be adjusted without removing the flywheel anymore, but first you must have it installed and that requires replacing the stock one with the adjustable one and the flywheel must be removed to do this. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted October 24, 2003 Author Report Share Posted October 24, 2003 I already have the adj timing plate installed. I went ahead and picke dup a flywheel puller anyways since I have needed it more than once now. it was only $15.. Seems I pull off the flywheel then adjust the timing plate my loosening the 3 screws and moving it to the proper alignment? Quote Link to comment Share on other sites More sharing options...
Forcefed Posted October 24, 2003 Report Share Posted October 24, 2003 Seems I pull off the flywheel then adjust the timing plate my loosening the 3 screws and moving it to the proper alignment? Yup...but if you can adjust it without removing the flywheel, I would suggest that route. Either way you decide to do it....be patient ! :wink: Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted October 25, 2003 Author Report Share Posted October 25, 2003 I can't get to the screws without removing the flywheel, Anny suggestions on getting the flywheel nut off? It just turns the crank Quote Link to comment Share on other sites More sharing options...
