10dmbanshee Posted April 15, 2013 Report Share Posted April 15, 2013 Weight is a big difference to lol. Quote Link to comment Share on other sites More sharing options...
10dmbanshee Posted April 15, 2013 Report Share Posted April 15, 2013 Don't rember mph 60fts were in the 1.50s Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 16, 2013 Report Share Posted April 16, 2013 If you don't know what the peak hp rpm of your motor is there's no way to give suggestions. For example I have a 10 mil Cub with high port timing that I run 15/42 and another that I run 16/42 with the same tires. That's a pretty big difference. One revs out about 600 to 800 rpms more. The times are similar, but the higher revving one has ran it's best of 3.79 with me riding @185 lbs. similar best times with Jockeys @3.71, though I didn't make appropriate changes for the lighter riders. There is a way to figure out what rpms your motor is pulling at the traps. Just gear it a tad low to make sure it's wound tight, then use your trap mph, gearing, and roll out to calculate rpm. Of course it's approximate because the tires grow, and are spinning. Quote Link to comment Share on other sites More sharing options...
possum Posted April 16, 2013 Report Share Posted April 16, 2013 ^^what tire do you run that gearing? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 16, 2013 Report Share Posted April 16, 2013 72 R/O 14 staggered. I have ran 76 R\O as well but went up a couple of teeth on the back I think. 3.5 psi max in either tire. Quote Link to comment Share on other sites More sharing options...
m671054 Posted April 16, 2013 Report Share Posted April 16, 2013 Jmadd whats your thoughts on the 15 out the back and no lockup Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 19, 2013 Report Share Posted April 19, 2013 15 outback can work fine. A lot of LRE chassis are long. You won't get many passes out of a clutch with no lockup. Plus the spring would have to be so heavy you wouldn't 60 ft. Quote Link to comment Share on other sites More sharing options...
