override
mx1986
Slighty more to it. each configuration is different. cut the dogs. evenly and at x angle. cut the wheel gears every other clutching tooth off. Cut the drum to allow last gear used to stay engauged. most require additional 3-4 slider with no dogs at all and some require springs on gear mainshafts. then if you want n down its a whole nother story.
