535 cheetah topend (complete), 535cases, 10mil cranks work crank,Hinson billet basket
Hey fellas got a polished 535 cheetah top end(complete)
Cylinders ported by WK racing. Comes with reeds,39mm intakes,pistons,base gasket,domes,head, and all hardware-1000shipped
10mil crank works crank(115mm rod) Has max load and tz bearing. Great shape maybe 20hrs on it if that-650shipped
Brand new Hinson basket with cushions-140shipped
I'll get pics of everything later tonight
1. Oem basket(tight),pressure plate,hub(not pictured),oem springs,pusher-65shipped
5055F1D4-57D8-4FFB-9951-26B2DA268C73-481
7DA232CB-48AD-4543-BCD5-FC34E37DE3A2-481
E3E73247-92C7-4ECC-BE10-824F2FFCF288-481
2. Oem stator from a 99-75shipped
FCEF816B-EBBA-4F9B-B5F8-FB3C771DC444-481
CA95F587-9D1E-44AE-8A02-89ABABF8C1AC-481
3.brand new Hinson billet basket & cushions-140shipped
92A85E2F-4C40-4F8F-99A2-E64F266E25E7-481
C6E7507B-AF1E-4B45-A5BB-7AA92CB506CE-481
85BFF5FC-76BA-4582-8DB5-CDC36DB6B546-481
54607593-D467-42C0-8C2D-7A92FEC17890-481
4. Set of 39pws's (gas)-325shipped
7ED41DC4-D27C-4F55-B24E-D21534FF08F4-481
69F32891-0889-4D18-8890-90B1C5DC169A-481
5.oem clutch cover(complete) with water pump & cover,insert,dipstick,hardware-40shipped
863565AC-0B97-49F6-9F3A-6BA957D86285-481
BAEE18F1-1C41-4428-BEC6-F372EC55B87B-481
6.complete stock trans(complete) drum,forks,gears,shaft,spring,boss,etc..-110shipped
1537BD0B-9719-4F32-99F7-5563B31B25CE-481
7.polished/ported WK racing 535 cheetah topend(head,cylinders,domes,upp intakes,reeds,pistons,.031 base gasket,block off plates,hardware, & cases bored&ported to the 535 cylinders-1400shipped
507C8F4C-5F75-4385-B203-80939D1CCC9D-481
3208C614-CF0D-4CA2-8D19-E81519082494-481
2E6B2DAD-FEA0-4763-B517-D403E1D2CBB1-481
B7078D7A-C03C-4C1A-98CD-BE2D9F5D52D8-481
80AA9CCD-EB0E-4039-9733-D7FE5BD6210E-481
61994F4B-AC0C-46E7-9A62-76E24AF91D18-481
72AB872C-0651-48AB-97B4-557FE9712D33-481
66BB332E-B61F-4177-B2E6-E11625705A77-481
7967F7D6-571C-4641-80FA-B5E0FFB7C663-481
D2B6E0FF-A0E4-46F8-BB73-1CBD92EBF260-481
27840AA8-7A60-415A-86D5-A51C302463B8-481
ED4B599D-25EB-4AC3-840C-1D7E60AE7B70-481
i just pulled a magnet off the fridge to see if it wud stick to the inside wall of the cylinder and it didn't. I bought these from a member who had got them from another very reputable member on here. so I know there should not b any problems with em at all.
