jscharphorn Posted April 11, 2013 Author Report Share Posted April 11, 2013 Right, and a bunch of it really, they are good people, I guess it might have to do with there new stock because he confirmed everything with the parts he has in stock. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted April 11, 2013 Report Share Posted April 11, 2013 Arms bolted up no problems, set the camber, caster and toe to my specs and rocked out! Evols bolted up in minutes as well. Second season on it all, jumping , playing around and giving the bike the weekly beat down mountain rides. Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted April 14, 2013 Author Report Share Posted April 14, 2013 Well to top all of this off I also purchased a alba steering stabilizer for my banshee, I just went to install it and the dang thing is for a YFZ450 I do not know if they are the same or not until I call them but I do know the instructions are for the 450 and not the banshee so even if it was the same I do not have proper instructions to install it and I can not install it until I can call them tomorrow seeing it is the weekend. I know the banshee and raptor 660 are the same stabilizer but I do not think the 450 is the same. Some of you might think that with all these problems why am I still buying stuff from them, well all of this came to light after the majority was purchased, the stabilizer was the only thing that was purchased after and only because they sold it to me for half price for the trouble, so I guess I got what I paid for, LOL Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted April 14, 2013 Report Share Posted April 14, 2013 Bolts up the same. Lock tight bolts and be done. Instructions are for women... Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted April 14, 2013 Report Share Posted April 14, 2013 Sorry but the tie rods can not be switched around, they would not fit, seems the stock ball joints are a tad different size, they would not screw on but when I turned them around they went right on. So when you installed the new tie rods, you left the ball joint parts bolted to the spindle and the steering stem? Then unthreaded the shaft? Then when you put the new shaft in the flat spot is on the inside? Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted April 14, 2013 Author Report Share Posted April 14, 2013 So when you installed the new tie rods, you left the ball joint parts bolted to the spindle and the steering stem? Then unthreaded the shaft? Then when you put the new shaft in the flat spot is on the inside? Yes that is correct, and to even assure you that the ball joints were not on backwards I had to replace one of the outside ball joints and I ordered a outside ball joint and it was the correct one Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted April 14, 2013 Author Report Share Posted April 14, 2013 I ordered directly from Alba and dealt with Cory Quote Link to comment Share on other sites More sharing options...
thomas h. Posted April 15, 2013 Report Share Posted April 15, 2013 Alba has my vote too. I just had a DS650 crap out and they fixed it cheap. Super happy. Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted April 15, 2013 Author Report Share Posted April 15, 2013 The 450 is the same. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted April 15, 2013 Report Share Posted April 15, 2013 Bolt up and Blue Lock tight. Quote Link to comment Share on other sites More sharing options...
Wertzy Posted April 17, 2013 Report Share Posted April 17, 2013 I have a set of their gullwing +2+1 arms on my Shee. Everything bolted up perfect and I'm running LT Fox Podiums. I do need to order new ball joints for the arms however. Hopefully they don't cost an arm and a leg lol. Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted April 18, 2013 Author Report Share Posted April 18, 2013 I installed the alba steering stabilizer and I would not recommend this product. I had to modify it as well, the clamp that goes around the stabilizer and the hiem joint for the frame mount will flop around so after everything is mounted and tight the stabilizer will flop around and rattle. I had to drill out 2 washers as shims so it would tighten up. you need to put one on each side of the hiem joint to take up the slack it has. I have a streamline that I purchased for my raptor 660 and do not have this problem and it was nice and tight Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 19, 2013 Report Share Posted April 19, 2013 My Denton is pretty tits Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted April 28, 2013 Author Report Share Posted April 28, 2013 I nicked my first stump and I think it blew the stabilizer out, only has pressure in the highest setting, I am sending it back. for a refund and getting another stream line Quote Link to comment Share on other sites More sharing options...
ph2smoke Posted July 24, 2013 Report Share Posted July 24, 2013 I have the Alba arms on my abnshee. I purchased them about 10 months ago and they are looking and working like new. I installed them pretty easily with no mods. Quote Link to comment Share on other sites More sharing options...
