special06shee Posted April 7, 2013 Report Share Posted April 7, 2013 if you have a "drag" ported cub, and are going to be racing more then anything, then it is a no brainier. go with the in frame drag pipe that has been proven time and time again that makes the most power. shearer!! if you were more geared toward trails, hills, stuff that requires a bit more bottom end then the cpi would be a better choice. I had a redline ported 421 cub.(not drag ported) Cameron more or less tried to extract the most amount of usable power out of the cyl. and domes.. that motor really liked the sb cpi's. Quote Link to comment Share on other sites More sharing options...
Methfireroad Posted April 7, 2013 Author Report Share Posted April 7, 2013 So shearers for the WIN!!!!!! Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted April 8, 2013 Report Share Posted April 8, 2013 Dg has what you need Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted April 8, 2013 Report Share Posted April 8, 2013 If you've got $450 to spend right now, like said previously, I'd save your pennies and just buy a set of new ones. You won't find a better pair of pipes, that's for sure. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 9, 2013 Report Share Posted April 9, 2013 I've got some like new Chrome Vitos Fat Bastard pipes. Look almost identical to Shearers. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted April 9, 2013 Report Share Posted April 9, 2013 Pretty much shearers, just built to Vito's specs. <br /><br />Sent from my SGH-T679 using Tapatalk 2<br /><br /> Quote Link to comment Share on other sites More sharing options...
Methfireroad Posted April 9, 2013 Author Report Share Posted April 9, 2013 Thanks everyone. Bought some shearers new Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 9, 2013 Report Share Posted April 9, 2013 If you have a motor ported for CPIs its gonna be down on power and maybe hold heat with Shearers. Check the exhaust port duration. If its higher than ~ 198* the CPIs usually work better. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted April 9, 2013 Report Share Posted April 9, 2013 If you have a motor ported for CPIs its gonna be down on power and maybe hold heat with Shearers. Check the exhaust port duration. If its higher than ~ 198* the CPIs usually work better. Only if the compression is high too. He's set up for pump gas. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted April 10, 2013 Report Share Posted April 10, 2013 He cancelled his order and got some fatties. Fatties need love too stvn:D Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Methfireroad Posted April 10, 2013 Author Report Share Posted April 10, 2013 It's T5s that I ordered Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted April 10, 2013 Report Share Posted April 10, 2013 Shoulda got the 6's Quote Link to comment Share on other sites More sharing options...
