tdod101 Posted April 5, 2013 Report Share Posted April 5, 2013 So the left pipe doesn't get nearly as hot as the right and barely smokes. Also lacks power. Crank or piston ? Quote Link to comment Share on other sites More sharing options...
tdod101 Posted April 5, 2013 Author Report Share Posted April 5, 2013 compression test, ohm test plug boots, stator, inspect reeds, change plugs, check ground, clean carbs. Heres a small list of things you can start with All of that has been done already. Everything checks out Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted April 5, 2013 Report Share Posted April 5, 2013 Try swapping carb caps/slides... Put the right on the left and the left on the right, they might be backwards Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted April 6, 2013 Report Share Posted April 6, 2013 Throw it in the trash, 2-strokes are way too complicated. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted April 6, 2013 Report Share Posted April 6, 2013 have you tried syncing the carbs? adjust your idle? ive had it before when first firing the bike where it would drop the left cylinder at idle because I didn't have the idle high enough on that side. The sync tool that Jeff at FAST racing sells pretty much takes the cake for being one of the greatest tuning tools... Quote Link to comment Share on other sites More sharing options...
tdod101 Posted April 6, 2013 Author Report Share Posted April 6, 2013 Throw it in the trash, 2-strokes are way too complicated. Take your sarcastic remark and stick it up your ass mother fucker, if you don't have an answer that can contribute then don't post you stupid fuck Quote Link to comment Share on other sites More sharing options...
04zSpittinKlotz Posted April 6, 2013 Report Share Posted April 6, 2013 Woooooo ^ too bad , that guy probably could have helped you..... Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 6, 2013 Report Share Posted April 6, 2013 Man, sure is a lot of new folks around here working the aggressive assertion angle lately. Go through the trouble of a leak down yet? Quote Link to comment Share on other sites More sharing options...
Finch Posted April 6, 2013 Report Share Posted April 6, 2013 Take your sarcastic remark and stick it up your ass mother fucker, if you don't have an answer that can contribute then don't post you stupid fuck I like this guy! Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted April 6, 2013 Report Share Posted April 6, 2013 To OP, what have you tried so far. All we know is that one pipe doesn't heat up. That tells us nothing more than it just don't run right. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted April 6, 2013 Author Report Share Posted April 6, 2013 To OP, what have you tried so far. All we know is that one pipe doesn't heat up. That tells us nothing more than it just don't run right. I've cleaned carbs, replaced all jetting one size over stock new plugs tested all electrical changed reed gaskets put new carb boots on took off the pipes to make sure they were clear of oil or crud, all that seems fine Quote Link to comment Share on other sites More sharing options...
tdod101 Posted April 6, 2013 Author Report Share Posted April 6, 2013 And a leak down test, Quote Link to comment Share on other sites More sharing options...
