Sounds like a right side broken piston ?
You cannot just throw pistons in that and expect it to run....
You need to split those cases and clean/find the rest of that piston skirt.  Not to mention I can see the scars on the piston that DIDN'T shatter.  So at the least you need to get those cylinders bored and honed, along with splitting the cases to find the rest of that skirt.  While your there you might as well go and put new seals throughout the motor, along with a pancake bearing.
yes my mechanic is going to split the case to remove the little bit of metal that's in there! I was just asking what will cause my piston to break!
