New crank seal leak! stumped! please help!
DEREEL
After doing a leak down test on my new build, no leaks were found accept for the crankshaft seal on the clutch side. It has a pretty nasty leak around the collar of the primary gear. Its only leaking at one spot, but the leak moves as u rotate the gear. I took the gear off and used a scotch brite pad to make sure the collar was very clean and didnt have any burs or imperfection causing it to leak. Put it back on making sure the washer convex side was facing the correct way, torqued it to spec and it still fkn leaks!!! Anyone have any ideas on how to fix this problem?
