04_blu_shee Posted April 2, 2013 Report Share Posted April 2, 2013 I have my cases and all parts cleaned getting ready to put my motor back together, Do you guys put case sealer on the Crank Seals or not. And a second question when I took my shift forks off of the shafts I had to tap on the plug on the case half to get the shafts out. I just tapped the plug back in place, will it leak now or will it still have a good seal. Quote Link to comment Share on other sites More sharing options...
Nieskes Posted April 2, 2013 Report Share Posted April 2, 2013 I have never put sealer on the seals and have never had a leak, I have always just used grease around in inside were it seals on the crank. And why did you not just pull the shafts out the clutch side? Quote Link to comment Share on other sites More sharing options...
Finch Posted April 2, 2013 Report Share Posted April 2, 2013 i dont seal the seals just run the sealer up on to them a lil bit. and im not sure about those plugs i was under the impression they shouldnt come out Quote Link to comment Share on other sites More sharing options...
04_blu_shee Posted April 2, 2013 Author Report Share Posted April 2, 2013 I couldnt get them to slide out and yes I do know they come out the clutch side, had em out before. Quote Link to comment Share on other sites More sharing options...
m671054 Posted April 2, 2013 Report Share Posted April 2, 2013 Green locktight on plugs Quote Link to comment Share on other sites More sharing options...
Starwriter Posted April 2, 2013 Report Share Posted April 2, 2013 They're not really supposed to be taken out, but you can get new ones from Yamaha. I worked on a bike that had 1 of the plugs leaking. I figured I could drill and tap the plug and stick a screw in it and pry the plug out. I started with a small drill bit. Well, even though I drilled with very light pressure, the plug started to spin. Eventually I was able to get a hole drilled into it deep enough to get a sheet metal screw started into it and then it pulled out with very little effort. Even though I had already bought a new plug from Yamaha, I decided that the hole in the case was probably too loose, so I made my own plug on the lathe with a .003" taper and drove that sucker in with some loctite. Quote Link to comment Share on other sites More sharing options...
Finch Posted April 2, 2013 Report Share Posted April 2, 2013 weld em in Quote Link to comment Share on other sites More sharing options...
