Kick Starter
chad06
Here's what I do...  http://forums.bansheehq.com/viewtopic.php?...ight=kicker+mod
If you want to send it to me, I'll do it for $5 but you have to pay shipping both ways.
I want to do this mod but cant get the kicker off the knuckle. Any tips for getting the screw out? Also is the stock spring used or do i need to get a different spring too?
The philips head screw is almost always messed up. If I can't unscrew it, I use a sharp chisel and put it in one of the screw slots. I angle the chisel to match the angle of the cone or countersink on the back of the screw. Usually I can chisel it around and make it unscrew. Drilling it out is not really possible unless you drill a small hole in the opposite end {the threaded end} of the screw and then try the screwdriver or chisel treatment. Don't try to drill it out from the head side or you'll never get it out.
