badbanshee509 Posted March 26, 2013 Report Share Posted March 26, 2013 so i recently bought a banshee that i want to use for trail riding, its a great bike however it dosent have any lights(front or rear), so i pulled a schamitic for the banshee off line and i see how the wiring is done for the lights, the low beam ties to theyellow/red & green wire, and the high beam ties to yellow/red & yellow wire so my question is, since i dont have the light switch mec. on my handle bar ither, i would like to put a toggle switch somewhere on the bike, i dont have a voltage regulator so will it be ok to just tie the toggle switch to the yellow/red & yellow for constant high beam with out the voltage regulator? or will it be safe to just tie it to the the yellow/red &green for low beam with out an issue, im trying to stay away from having to buy a voltage regulator but have lights for trail riding with a toggle switch. WITH OUT HURTING MY BIKE. ANY ADVICE WOULD BE HELPFUL!!!!! Quote Link to comment Share on other sites More sharing options...
badbanshee509 Posted March 26, 2013 Author Report Share Posted March 26, 2013 what if i just ran it direct to the low beam side, will is still blow bulbs? Quote Link to comment Share on other sites More sharing options...
badbanshee509 Posted March 26, 2013 Author Report Share Posted March 26, 2013 cool, just got one off of e bay, now will i be able to run this rigid industries led, those exact ones, i will order them if it will work. link at bottom http://www.rockymountainatvmc.com/p/43/53/160/1195/-/36159/Rigid-Industries-Dually-2x2-LED-Lights?term=banshee+led+lights Quote Link to comment Share on other sites More sharing options...
Dunes98 Posted March 26, 2013 Report Share Posted March 26, 2013 If you have not done a DC conversion, you cant run thoes LED's. Well you can, they just wont last long. Use the search to look up floating the ground. Its a very easy upgrade to do. You will also need a battery and a REG/REC. All can be found on this web site. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted March 26, 2013 Report Share Posted March 26, 2013 You can't use a stock regulator for LED lights. If you want to run LED lights, you need to do a DC conversion. Search and read Quote Link to comment Share on other sites More sharing options...
badbanshee509 Posted March 26, 2013 Author Report Share Posted March 26, 2013 so is it just better to go with trail tec lights instead, link below says will work with stick banshee or modded banshee, if so ill just save the time and get these, i see many banshee with theses aswell, i dnt know if you have to modd it make work http://stores.wildcardracingparts.com/-strse-3941/Trail-Tech-Atv-Lighting/Detail.bok Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 26, 2013 Report Share Posted March 26, 2013 Yes trailtecs will work just fine. Quote Link to comment Share on other sites More sharing options...
badbanshee509 Posted March 26, 2013 Author Report Share Posted March 26, 2013 i see many people putingtaking out the 35Wbulbs and replacing them with 50W bulbs on then trail tec,will this be ok to do on stock stator or should i stay with the 35W bulbs? Quote Link to comment Share on other sites More sharing options...
Starwriter Posted March 26, 2013 Report Share Posted March 26, 2013 i see many people putingtaking out the 35Wbulbs and replacing them with 50W bulbs on then trail tec,will this be ok to do on stock stator or should i stay with the 35W bulbs? 50w bulbs will be dimmer with the stock stator. Quote Link to comment Share on other sites More sharing options...
barahonapr Posted March 27, 2013 Report Share Posted March 27, 2013 so trail techs run just fine on a stock stator.. Quote Link to comment Share on other sites More sharing options...
badbanshee509 Posted March 27, 2013 Author Report Share Posted March 27, 2013 that my question, does trail tech run fine on a stock stator with a 35W bulb system without hurting anything, i see thousands of people running them on their banshees but i never ask them about the wiring, i have already ordered the trail tech lights and the discription says for banshee so im guess is that it will be fine, hope some one clears this up!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Dunes98 Posted March 27, 2013 Report Share Posted March 27, 2013 Yes, it will be okay to run those on your stock stator. If you do alot of night riding, I would strongly consider doing a DC conversion and running LED's. I love mine, and they are ten times brighter than the trail techs your buying. Its also a plus to be able to run your lights at night while sitting down in the bottom of a bowl at the dunes without running your engine. Just some food for thought.. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 27, 2013 Report Share Posted March 27, 2013 Yes trailtecs will work just fine. Yes trailtecs will work just fine. Quote Link to comment Share on other sites More sharing options...
badbanshee509 Posted March 27, 2013 Author Report Share Posted March 27, 2013 no, i dont do much night riding, im only puting lights on so if i ever want to then they will be their, maybe later down the line i will do a dc conversion but as of rite now i dont see the need, and as long as the trail tech are brighter then stock i think the will do fine, Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted March 28, 2013 Report Share Posted March 28, 2013 Later on you could do a dc conversion and use led bulbs in your trailtech lights. Mr16 6w led = 50w halogen Quote Link to comment Share on other sites More sharing options...
