lugene Posted March 26, 2013 Report Share Posted March 26, 2013 what's the difference ? Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 26, 2013 Report Share Posted March 26, 2013 lmgtfy A Stroker kit is an aftermarket assembly that increases the displacement of a reciprocating engine by increasing the travel of the piston Quote Link to comment Share on other sites More sharing options...
foxrider603 Posted March 26, 2013 Report Share Posted March 26, 2013 As far as I know and I could be wrong is it has to do with the piston rod length Quote Link to comment Share on other sites More sharing options...
lugene Posted March 26, 2013 Author Report Share Posted March 26, 2013 lmgtfy A Stroker kit is an aftermarket assembly that increases the displacement of a reciprocating engine by increasing the travel of the piss so in a better form of explaining ,it's like puttin a 4mm crank right or am i wrong? Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted March 26, 2013 Report Share Posted March 26, 2013 As far as I know and I could be wrong is it has to do with the piston rod length Yes u would be wrong. A stroke change changes the pin location on the crank further from the centerline of the crank. So if u were to look at the crank from the side the pin that locates the rod is further away from center. So when it goes around it makes a bigger circle. That make any sense? Quote Link to comment Share on other sites More sharing options...
m671054 Posted March 26, 2013 Report Share Posted March 26, 2013 Long rod or short rod referd to rod length. On most stroker cranks you use longer thsn stock rods for the piston skirt to clear the crankwheels at bdc. anything over a 4 mill requires trenching the cases for clearance. over 10 requires epoxy so you dont trench all the way through. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 26, 2013 Report Share Posted March 26, 2013 You could have a rod 12" long and you still be stroking it 54mm Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted March 26, 2013 Report Share Posted March 26, 2013 On most stroker cranks you use longer thsn stock rods for the piston skirt to clear the crankwheels at bdc. anything over a 4 mill requires trenching the cases for clearance. over 10 requires epoxy so you dont trench all the way through. Quote Link to comment Share on other sites More sharing options...
Abe Posted March 26, 2013 Report Share Posted March 26, 2013 You could have a rod 12" long and you still be stroking it 54mm who would need to stroke it if you had a 12" rod , you be getting paid to let other people do it Quote Link to comment Share on other sites More sharing options...
lugene Posted March 26, 2013 Author Report Share Posted March 26, 2013 so as far as i understood stroker is changing the pin location further from the center so the piston can make longer rotations... ok does it increase your performance or hp? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 27, 2013 Report Share Posted March 27, 2013 correct.... and it causes an increase in performance and hp as due to the larger amount of displacement in your cylinders. More room = more ability to place more air/fuel charge into. More air'fuel charge......more to go boom. Now the hp thing.....while it is a yes.....remember that hp is just a derived number creating another measurement number based upon your motors ability to create torque at certain rpms. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 27, 2013 Report Share Posted March 27, 2013 Night and day. Simple. Quote Link to comment Share on other sites More sharing options...
m671054 Posted March 27, 2013 Report Share Posted March 27, 2013 So what increases performance more? big bore or big stroke. same cc engine. Quote Link to comment Share on other sites More sharing options...
lugene Posted March 27, 2013 Author Report Share Posted March 27, 2013 great help THANKS GUYS Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 29, 2013 Report Share Posted May 29, 2013 So what increases performance more? big bore or big stroke. same cc engine. stroker coz it also increases dwell time at top dead center releasing more energy into your piston and a longer rod provides more leverage and produces more torque...but no-one ever really mentions that coz...um...its gayass shit and everybody knows it maaaan Quote Link to comment Share on other sites More sharing options...
