bansman76 Posted March 26, 2013 Report Share Posted March 26, 2013 well i finally got my motor built over the wknd. put leakdown tester on it tonight and will build pressure but as soon as i turn compressor off the air leaks right back out around the keyway on the crank( clutch side ) . i need some ideas on what to do next please.. Quote Link to comment Share on other sites More sharing options...
LawDog Posted March 26, 2013 Report Share Posted March 26, 2013 take it apart and put case sealer on key. its a common issue. Quote Link to comment Share on other sites More sharing options...
Tech AS Posted March 26, 2013 Report Share Posted March 26, 2013 Im not sure that using a compressor to pressurize your motor is a good idea since its real easy to blow out your seals. But as for the question, I've never had that issue personally but I've heard to remedy that you gotta take the key out and put in a dab of the sealant you used to seal the cases in there then replace the key. Let it cure then retest. Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted March 26, 2013 Report Share Posted March 26, 2013 I always seal up all that stuff on that side. Between the gears and the key way. Doesn't take much. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 26, 2013 Report Share Posted March 26, 2013 Little ultra grey or three bond. Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted March 26, 2013 Report Share Posted March 26, 2013 X2 on putting sealant on the keyway. Quote Link to comment Share on other sites More sharing options...
bansman76 Posted March 26, 2013 Author Report Share Posted March 26, 2013 ok guys ill try that when i get home from work. thanks p.s. im using my little slime compressor not my big compressor lol Quote Link to comment Share on other sites More sharing options...
mike0chek Posted March 26, 2013 Report Share Posted March 26, 2013 i had the same problem... Quote Link to comment Share on other sites More sharing options...
bansman76 Posted March 27, 2013 Author Report Share Posted March 27, 2013 sealed the keyway and resealed my intakes and all is good..motor going in frame tomorrow...thanks for the help guys Quote Link to comment Share on other sites More sharing options...
