gas or methanol?
pump fuel = readily available and motor common, longer lasting rides.....will not support as much compression/timing.    With methanol, your going to get way worse time out riding as bike will drink close to twice as much methanol, however methanol will support higher compression/timing safely, and will also run cooler....
Alky= less ride time but you gain a little more hp and tq. There is nothing to purging I only purge when it's going to set for a long time in between rides.
I was purging 4 fuckin bikes just so they could sit for a week until we ran them again. I know now that they can sit a lil longer without having to purge. If it gets easier to get this season I will go back to alky. And this season I'll have someone to do it for me so I won't have to bitch about it:D
Sent from my SGH-T679 using Tapatalk 2
  • Like 1
What brand of alky do you guys run VP or sunco? Also will lubed methanol fuel work for a drag banshee?
You want M1 VP the lubed stuff is more for 4 pokes ive heard you can run it but very hard to tune correctly, stick with the M1
