On my Shee it came with a round slide mic.
was wondering what size they are & Model.
Both are a right side choke, pull style type plunger, left carb choke is plugged.
The only numbers i see on them are stamped in are as follows.
T2
X10
58
01B
How are the numbers coded?
they measure about 33mm in the intake side of the bore. Pre VM model maybe?
I need order a new choke.
They looks like a VM series round slides. but they may Pre date those.
If i was to quess I would say they came off of an old snowmobile from the 70's.
they work great on the top end but am thinking after reading your tunning guide Benbb that my pilot jets are wrong. it could be over ported and not the carbs but i need to test a few things out.
It has no pulling power until you hit upper mid to top end. and I mean no power. I compair this to my sons 2003 with PC or CPI which pulls like a tractor compaired to my shee.
My pipes are FMF gold series.
300 mains
pilots 55
needle middle clip postion
air screws 3.5 turns out
K&N pods
lightly ported TDR's reeds .20 thick.
this is a dune machine strips and light as possible.
does it sound like its to fat in the pilots?
I am trying to help this area out and any tips are greatly appreciated.
