foxrider603 Posted March 24, 2013 Report Share Posted March 24, 2013 So my banshee just got a top end job did the heat cycles and it seems to smoke more out of the right pipe and once in a while the side that doesn't smoke as much makes a popping noise when you Rev it not every time but enough to where its worrisome, any idea what the issue is. I'm running a 2 into 1 intake keihin Carb , no airbox , no tors. Not sure if it plays a factor but its been about 40degress for the two days since the rebuilt was complete Quote Link to comment Share on other sites More sharing options...
tdod101 Posted March 24, 2013 Report Share Posted March 24, 2013 Perhaps one of your pipes is clogged ? I would switch back to dual carbs as well. Try dual carbs and see what happens Quote Link to comment Share on other sites More sharing options...
foxrider603 Posted March 24, 2013 Author Report Share Posted March 24, 2013 Not sure if this is the issue but the rubber boot that connect the expansion chamber to the exhaust pipe is rather lose definitely not air tight. Would that be the cause Quote Link to comment Share on other sites More sharing options...
tdod101 Posted March 24, 2013 Report Share Posted March 24, 2013 Not sure if this is the issue but the rubber boot that connect the expansion chamber to the exhaust pipe is rather lose definitely not air tight. Would that be the cause Could be yea. Change it and find out. Or use a pop can and some band straps Quote Link to comment Share on other sites More sharing options...
foxrider603 Posted March 25, 2013 Author Report Share Posted March 25, 2013 Alright so I put better clamp on that rubber piece and that side started smoking more . Pulled my plugs and the side that was smoking more had small amounts of coolant on that one plug so I re torqued all my head bolts some were looser then they were supposed to be . That seemed to take care of that problem I'm not seeing any coolant on that plug anymore. But I do have a good amount of oil coming out of my right exhaust pipe, enough to coat my finger if I stick it in the exhaust. The left side does it to but not nearly as bad. Any ideas? Am I running to much oil in my gas, I'm running it right now 40-1, I know every bike is different some run better with more oil to gas and vice versa. Would running a 50-1 get ride of the excessive oil in my exhaust? Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted March 26, 2013 Report Share Posted March 26, 2013 Stop riding and do a lean down test. Leak down test should of been done before you even fired that bike up the first time IMO. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted March 26, 2013 Report Share Posted March 26, 2013 Leak down* Quote Link to comment Share on other sites More sharing options...
