AustinONeal Posted March 23, 2013 Report Share Posted March 23, 2013 Go a 44 lectron and I need to know what to set the metering rod at, because when I received it it was set at 52mm and I was not sure if that is neutral setting for a 250r. set up on alcohol is the same as a banshee as far as 48.5? Thx guys Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted March 23, 2013 Report Share Posted March 23, 2013 Austin , I think on the 44mm and the bigger 250rs the neutral/ starting point is like 49.6mms. Flat side of the needle facing reeds/motor of course. If it lean hangs or revvs high then thats lean of course and if its blubbery or blowing alky out on your hand after cleanin it out thats rich. A good snappy sound is what ya want. A little blue color to the smoke rather than white like steam when putting around shows its pretty close to right. Quote Link to comment Share on other sites More sharing options...
slobanshee Posted September 24, 2013 Report Share Posted September 24, 2013 Old post I know..... What if the smoke is white like steam? What's that? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 24, 2013 Report Share Posted September 24, 2013 Lean, or...... Coolant. Quote Link to comment Share on other sites More sharing options...
