Anthony133 Posted March 23, 2013 Report Share Posted March 23, 2013 Like i said in my previous for sale topics, all my toys and tools got stolen so i wont be needing this. When i got this engine it was run way too lean and scored the cylinders and melted pistons.... I took the entire motor apart, cleaned the cases out, installed new seals and put the cleaned trans back together. Didnt touch the crank, or stator or anything like that. I was told it worked perfectly before it quit so i myself wasnt able to test it. the trans is all together with the crank and bolts out. Clutch includes everything but the plates because those were junk and i tossed them. INCLUDES: Cases with chain whack and trans/shift linkage ect Crank with gears flywheel NEW wiseco wrist pin bearings Stator and timing plate kick start gears waterpump clutch cover all the bolts to put it all together front motor mounts $400 shipped? I can send pics, 708-224-8659 Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted March 23, 2013 Report Share Posted March 23, 2013 Txt sent Quote Link to comment Share on other sites More sharing options...
