How to drag cut a frame
Ray_barnes22
How to: Drag frame
1: cut cut cut cut cut cut cut cut
2: bend bend bend bend bend bend bend bend bend
3: weld weld weld weld weld weld weld weld weld
4: grind grind grind grind grind grind grind grind grind
5: bondo bondo bondo bondo bondo bondo bondo bondo
6: paint
You don't need a bender, or a good welder.
That is all.
thats scary nieskes.
We've all seen your work.. and your worried about his?   :rotflmao:
You're not running world class equipment, professionally built and tuned motors like he is Shayne. You can't compare what we do to Gumby motorsports.
Sent from my Nexus 10 using Tapatalk HD
