marcusb Posted March 18, 2013 Report Share Posted March 18, 2013 Ok so both of my exhaust pipes leak where it connects to the headers. There toomey t6s with silencers and ive changed the o rings atleast 5 times and still, its leaking that sticky black crap and its all over. Running 220s if that helps, and yes im going to change them during my rebuild right now to about 270s. Any idea why it may be leaking?? Quote Link to comment Share on other sites More sharing options...
possum Posted March 18, 2013 Report Share Posted March 18, 2013 gray rtv on the flanges. bolt them up, clean off outside where it squeezes out. then let dry over night. BAM. 1 Quote Link to comment Share on other sites More sharing options...
monster Posted March 19, 2013 Report Share Posted March 19, 2013 When I install pipes. I clean all the pipe connections with brake clean. Then I only put the RTV on the male side so it only squishes out to the outside and not the inside causing a restriction inside the pipe. I like Toyota black FIPG the best it holds up to heat, looks beater then red high temp RTV. Seems like it has urethane strength to it. http://www.oemtoyotascionparts.com/00295-00103 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 19, 2013 Report Share Posted March 19, 2013 Not sure I agree much on the use of grey RTV. The red is good and that's what the 250r guys have proven for years. That Toyota stuff is Awesome! Tony Doukas put me up on that shit and I love it. Quote Link to comment Share on other sites More sharing options...
possum Posted March 19, 2013 Report Share Posted March 19, 2013 ive used them all. never had a problem with any color rtv. but i like gray for some reason and i seem to always have some. lasts a long time anywhere i put it. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 19, 2013 Report Share Posted March 19, 2013 I guess it helps that it kinda blends in with the metal if it splooges out to. The R guys are always bitching about red jizz all over their chrome! Quote Link to comment Share on other sites More sharing options...
Tony Doukas Racing Posted April 16, 2013 Report Share Posted April 16, 2013 The Toyota stuff is one of the best that I have found. It is called seal packing 103 FIPG I carry it in stock. As for the spooge. A little acetone or laquer thinner on a rag will clear it off before it dries. Quote Link to comment Share on other sites More sharing options...
joey83 Posted April 16, 2013 Report Share Posted April 16, 2013 Have you ever compared temp differences between grey and red? I've been told it's only about 50 degrees difference on max temp. Quote Link to comment Share on other sites More sharing options...
Uf21 Posted April 19, 2013 Report Share Posted April 19, 2013 Does the leak cause a loss of power? Quote Link to comment Share on other sites More sharing options...
