101Diesel Posted March 17, 2013 Report Share Posted March 17, 2013 Currently running a +6 with a 421 cub, 1-5 duneable override on methanol. The bike wheelies leaving the line every time and I have to let off the throttle. I'm 250lbs with 9 paddle extremes 72" ro 14/41 gearing. Should I go to a +10 or +12? Quote Link to comment Share on other sites More sharing options...
J Whitehurst Posted March 17, 2013 Report Share Posted March 17, 2013 If you still use the bike for play riding, a ten would be max. If you are drag only then a twelve is probably your answer. Then you can run more paddle. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted March 17, 2013 Report Share Posted March 17, 2013 You can try changing the gearing first Quote Link to comment Share on other sites More sharing options...
101Diesel Posted March 17, 2013 Author Report Share Posted March 17, 2013 No, the motor won't pull taller gearing on the hill. Quote Link to comment Share on other sites More sharing options...
101Diesel Posted March 17, 2013 Author Report Share Posted March 17, 2013 If you still use the bike for play riding, a ten would be max. If you are drag only then a twelve is probably your answer. Then you can run more paddle. Quote Link to comment Share on other sites More sharing options...
101Diesel Posted March 17, 2013 Author Report Share Posted March 17, 2013 I have to launch in first right now because the motor bogs trying to leave in second. Will the +10 give me enough wheel spin to leave in second? I don't want to have to drop another $300 on paddles... Quote Link to comment Share on other sites More sharing options...
m671054 Posted March 17, 2013 Report Share Posted March 17, 2013 Hows your clutch tune? what springs and arm setup? Quote Link to comment Share on other sites More sharing options...
possum Posted March 17, 2013 Report Share Posted March 17, 2013 i would do 16 41 or 17 41 coming out of first. Quote Link to comment Share on other sites More sharing options...
101Diesel Posted March 17, 2013 Author Report Share Posted March 17, 2013 Slingshot in good tune with oem springs. It has a yfz450 front end with elka stage 2's, the rear is a stock shock and I believe it was revalved. The swingarm is from the swingarm shop with a stock style carrier. I want to go to a round style 40mm and add an aluminum axle. The four wheeler was bought used... Quote Link to comment Share on other sites More sharing options...
101Diesel Posted March 17, 2013 Author Report Share Posted March 17, 2013 i would do 16 41 or 17 41 coming out of first. Is this for 300ft? I can't pull any taller than 15/44 or 14/41 on banshee hill in dumont. If I go taller then that the bike falls flat on its face from 4th to 5th. I wanted to try and get the bike to run 1/8 and 1/4 on sand flats, but was not sure if I should go to a 17t or 18t counter shaft sprocket. Quote Link to comment Share on other sites More sharing options...
J Whitehurst Posted March 17, 2013 Report Share Posted March 17, 2013 Don't take this the wrong way but my play bike is a 421 on gas, I can pull second gear starts all day long hard with 22" SLS 10 paddle extremes. Geared at 15/43. You may want to take a look at the motor and see if you have an issue bud. I am 260 lbs by the way. Mine pulls hard all the way through 5th on a long hill. The ten will allow for more wheel speed because of the weight transfer but I still think your motor should pull second gear launches with ease with 9 paddles. By the way my motor is a stock cub no porting. Quote Link to comment Share on other sites More sharing options...
101Diesel Posted March 17, 2013 Author Report Share Posted March 17, 2013 Don't take this the wrong way but my play bike is a 421 on gas, I can pull second gear starts all day long hard with 22" SLS 10 paddle extremes. Geared at 15/43. You may want to take a look at the motor and see if you have an issue bud. I am 260 lbs by the way. Mine pulls hard all the way through 5th on a long hill. The ten will allow for more wheel speed because of the weight transfer but I still think your motor should pull second gear launches with ease with 9 paddles. By the way my motor is a stock cub no porting. How many over on your swingarm? Quote Link to comment Share on other sites More sharing options...
J Whitehurst Posted March 17, 2013 Report Share Posted March 17, 2013 Six inch over SLC arched. Quote Link to comment Share on other sites More sharing options...
EZ2FLEE Posted March 17, 2013 Report Share Posted March 17, 2013 hell i run a 9 paddle extreme on my modified stock stroke, at 14/41 gearing and pull 2nd gear starts all day on only a +2 swingarm with no bog down and im 205 easy... u might wanna dig a little deeper....... Quote Link to comment Share on other sites More sharing options...
EZ2FLEE Posted March 17, 2013 Report Share Posted March 17, 2013 Six inch over SLC arched. arched makes no difference from straight Quote Link to comment Share on other sites More sharing options...
