jbmason Posted March 16, 2013 Report Share Posted March 16, 2013 Yesterday I was riding and I heard a little pop noise then it stopped I though it might be my exhaust coming loose so I checked it and it was fine rode it around the yard easy and heard it again this time doing a few times.... long story short I shut it off and fired it back up and it started rattling after a few seconds to describe the rattle it sounds like when you was a kid and put playing deck cards on your bicycle spokes sounds like that.. I'm thinking I have a crank bearing or lower rod bearing going out??? What yall think? Quote Link to comment Share on other sites More sharing options...
J Whitehurst Posted March 16, 2013 Report Share Posted March 16, 2013 Kind of sounds more like a gear problem with the rapid clicking you are describing. Could be as simple as a broken water pump impeller. Crack the clutch cover off and start there. You can usually feel a crank bearing bad when you roll the kick starter. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 16, 2013 Report Share Posted March 16, 2013 Maybe an idler gear Quote Link to comment Share on other sites More sharing options...
jbmason Posted March 16, 2013 Author Report Share Posted March 16, 2013 Kind of sounds more like a gear problem with the rapid clicking you are describing. Could be as simple as a broken water pump impeller. Crack the clutch cover off and start there. You can usually feel a crank bearing bad when you roll the kick starter. im guessing with the plugs out??? i will feel tight spots?? Quote Link to comment Share on other sites More sharing options...
camatv Posted March 16, 2013 Report Share Posted March 16, 2013 just take the cover off.. takes longer to type all this than to do that. Quote Link to comment Share on other sites More sharing options...
J Whitehurst Posted March 17, 2013 Report Share Posted March 17, 2013 Yes you will feel resistance without plugs in it, different than normal, almost like compression. Once you feel a bad crank under rolling kickstart you can pinpoint it pretty easy. Pull the clutch cover and start there. I do not think it is an idler but start there, stranger things have happened. I have experienced these motors make completely different sounds from the same problems. Quote Link to comment Share on other sites More sharing options...
jbmason Posted March 17, 2013 Author Report Share Posted March 17, 2013 I checked the water pump impeller all good there pulled the plugs and rolled the kick starter and have a tight spot where I have to "slam" the kick starter to get past and its fine till I get back to that point. Quote Link to comment Share on other sites More sharing options...
J Whitehurst Posted March 17, 2013 Report Share Posted March 17, 2013 Pull the cylinders. Sounds like a hung ring or a crank bearing. May as well pull the motor it is easier at this point bud, sorry. Quote Link to comment Share on other sites More sharing options...
jbmason Posted March 17, 2013 Author Report Share Posted March 17, 2013 it still has good compression and still runs good i redone the top end 2 yrs ago after i bought it.... should have went through the bottom too... i guess if i have to look at the bright side at least i caught it before it came apart. What mods are needed if any to run a 4mil crank? thanks fpr your help.. Quote Link to comment Share on other sites More sharing options...
J Whitehurst Posted March 17, 2013 Report Share Posted March 17, 2013 Nothing to the cases. Give Cam a call and have him set up your cylinders for a 4 mil. Best way to go when the crank goes shit. Quote Link to comment Share on other sites More sharing options...
jbmason Posted March 19, 2013 Author Report Share Posted March 19, 2013 when I tear the engine down what things should I replace while I got it all apart? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 19, 2013 Report Share Posted March 19, 2013 get a seal kit and replace ALL the seals on the motor. may want to look into getting a billet water pump also. Quote Link to comment Share on other sites More sharing options...
jbmason Posted March 22, 2013 Author Report Share Posted March 22, 2013 I tore most of it down waiting on my flywheel puller to come in.. one of my pistons skirt has a chunk broke out of it and I have no idea what caused it. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 23, 2013 Report Share Posted March 23, 2013 excessive slop between the piston and the piston wall Quote Link to comment Share on other sites More sharing options...
jbmason Posted March 24, 2013 Author Report Share Posted March 24, 2013 I think im going buy a 4 mil setup with everything I have been looking at herjuggsracing 4 mill kit and bore and port and polish about the best deal I found. what do you all think??? i have a cool head with 20 cc domes do you have to have special cut domes for 4 mil??? Quote Link to comment Share on other sites More sharing options...
