ready to push this thing over a cliff!
sorry to bother you guys but im out of options on what to look at on this dam thing...
I just did a rebuild on my banshee with trinity stage 3 ported cylinders and vforce4 reeds...
the first start I had to push start it to get it to fire up and run, after that it starts up first kick.
A couple days later ill have to kick it 50 times even with the 30 pilots in and ive cleaned the carbs 3 times
everything electricals been replaced...
Ive heard ported cylinders have lower compression untill started? I pull the plugs out and there dry after i kick for abit...
used to start right up no problem, heres my engines mods
pro design coolhead with 20cc domes
trinity stage 3 dune port cylinders
.30 weiseco pistons
welded crank with maxload and tz bearings
vforce 4 reeds
30 pilot 340 mains, alba needles
uni filer no lid
fmf fatty and powercore 2's
billet impeller with engine ice coolant
+4 timing plate
tors removed
95+ hp clutch
Just joined the site but I have been playing this game for 20 years. Will not say I have seen it all but I have made all the mistakes and experienced plenty of Banshee problems. Change your stator and it will fire for you. When they get weak you cannot spin the motor fast enough by kicking it. It will fire when you pull start it due to the increased RPM to the stator. After it is warm the windings will make better contact for a while. I have fought this same problem until I wanted to rub shit in my hair. Change your stator to a good OEM and go play.
send your bike to me. ill take it before you push it off  a cliff.......hell its not the bikes fault you fucked up and sent perfectly good cylinders to trinity.  :shootself:
I was thinking the same thing:D
Sent from my SGH-T679 using Tapatalk 2
the stator was replaced a couple years ago and only used a summer...was in the warm house after that. just put a new pickup/cdi and ignition coil on
I clean one carb at a time so they never get mixed up, yes stock ones, crossover tubes on and float hights good.
I bought the cylinders already ported, still have the old ones and seem to work alright haha whats wrong with trinity? learn from the mistakes i guess..
it has LOTS of fire though...like i said, the plugs are still dry after kicking for awhile...then all of a sudden it starts and idles great.
