Bansheeteddy Posted March 12, 2013 Report Share Posted March 12, 2013 Posted Yesterday, 04:14 AM Ok guy I just now brought another banshee with a rebuilt engine 0.20 over Wisceo piston and stock tried and welded crank , Vito's billet cool heads still runs on pump gas . So what's the best spark plug for performance and the oil I was thinking about using is Klotz Oil R 50 Synthetic Racing Techniplate 16 Ounces KL-102 ? How many hours should I replace all the engine gaskets and bearings . What brand gaskets and bearings should I use? What's all the maintenance I should look out on the engine ? Quote Link to comment Share on other sites More sharing options...
oldskool Posted March 12, 2013 Report Share Posted March 12, 2013 NGK B8ES or B9ES. Your oil choice is good. Use oem gaskets, but if its not broke don't fix it. Air leaks are what you want to look out for. You need a leakdown tester. Quote Link to comment Share on other sites More sharing options...
Bansheeteddy Posted March 12, 2013 Author Report Share Posted March 12, 2013 NGK B8ES or B9ES. Your oil choice is good. Use oem gaskets, but if its not broke don't fix it. Air leaks are what you want to look out for. You need a leakdown tester.Ok so I can go to autozone and give them that plug number , and I wanted to change my Exhuast to t5's or trinity . An I want to add some V-force 4 reeds , Rees spacer , with 28-35mm carbs , billet water pump , aluminum radiator , aluminum air box with twin K&G air filter , billet manifolds. An what's are some great snapping clutch kits ? 1 Quote Link to comment Share on other sites More sharing options...
mike0chek Posted March 12, 2013 Report Share Posted March 12, 2013 Ok so I can go to autozone and give them that plug number , and I wanted to change my Exhuast to t5's or trinity . An I want to add some V-force 4 reeds , Rees spacer , with 28-35mm carbs , billet water pump , aluminum radiator , aluminum air box with twin K&G air filter , billet manifolds. An what's are some great snapping clutch kits ? save yourself some money and skip buyin reed spacers Quote Link to comment Share on other sites More sharing options...
James_21 Posted March 12, 2013 Report Share Posted March 12, 2013 ^^^ agree as well, Only need those spacers on bigger motors Quote Link to comment Share on other sites More sharing options...
Bansheeteddy Posted March 12, 2013 Author Report Share Posted March 12, 2013 Ok I will skip that ! Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 12, 2013 Report Share Posted March 12, 2013 FAST Racing (farmandsandtoys.com) has the cats ass of clutches.....a lot of guys on here run his clutch and have never had problems. Also a lot of guys run those clutches in their drag bikes and say they hold together DAMN GOOD. Quote Link to comment Share on other sites More sharing options...
Bansheeteddy Posted March 13, 2013 Author Report Share Posted March 13, 2013 FAST Racing (farmandsandtoys.com) has the cats ass of clutches.....a lot of guys on here run his clutch and have never had problems. Also a lot of guys run those clutches in their drag bikes and say they hold together DAMN GOOD. Ok thanks for that info and what's a nice sprocket set up for my build I trail ride and drag race a lot . What type of boost bottle should I get ? Quote Link to comment Share on other sites More sharing options...
Nightmare Posted March 13, 2013 Report Share Posted March 13, 2013 Are you serious about the boost bottle:blink: Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 13, 2013 Report Share Posted March 13, 2013 Ok thanks for that info and what's a nice sprocket set up for my build I trail ride and drag race a lot . What type of boost bottle should I get ? shouldn't get a boost bottle, and stock gearing or a 15 up front is a good all around set up Quote Link to comment Share on other sites More sharing options...
James_21 Posted March 13, 2013 Report Share Posted March 13, 2013 Skip the boost bottle as well! Quote Link to comment Share on other sites More sharing options...
Bansheeteddy Posted March 13, 2013 Author Report Share Posted March 13, 2013 Skip the boost bottle as well! What size carbs should I get ? Quote Link to comment Share on other sites More sharing options...
Bansheeteddy Posted March 14, 2013 Author Report Share Posted March 14, 2013 What's the best company that makes pistons cause I was looking at Vito's .020 over pistons? Quote Link to comment Share on other sites More sharing options...
