sand_demon Posted October 20, 2003 Report Share Posted October 20, 2003 Hi I wanted to elimate the light switches from the handle bars and put a toggle switch for the high beams and lows. There is a green, blue, and two yellows. I was going to install some lazer stars, so would I even need the low beam or should I just only wire the high beam. Thanks Quote Link to comment Share on other sites More sharing options...
reas11 Posted October 20, 2003 Report Share Posted October 20, 2003 http://www.dunereview.com/bansheemanual.zip thats wyo duners site there is the banshee manual to tell u what wires do what .......holla Quote Link to comment Share on other sites More sharing options...
sand_demon Posted October 20, 2003 Author Report Share Posted October 20, 2003 sorry link don't seem to work for me? Quote Link to comment Share on other sites More sharing options...
reas11 Posted October 20, 2003 Report Share Posted October 20, 2003 sorry man he upgraded his site and must have moved the link ......ill try to find it ..... Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted October 20, 2003 Report Share Posted October 20, 2003 I run my illuminators on the low beam because they are only single filament anyways, like your lazer stars, I toggle back and fourth between teh stock and handle bar lights though. Quote Link to comment Share on other sites More sharing options...
boonman Posted October 20, 2003 Report Share Posted October 20, 2003 I ran a toggle switch directly from the stator output wire. I eliminated the entire stock junk. No need for it when you eliminate the switch. This however, is only if you are running single beam lights...... Quote Link to comment Share on other sites More sharing options...
sand_demon Posted October 20, 2003 Author Report Share Posted October 20, 2003 How do I run it from the stator directly? Is it those two wires coming out(yellow,black). Do I need to put some kind of fuse or regulator so I won't fry the lights? I just got a new ricky 200 watt stator for this glamis halloween trip and want to have my lazer stars ready. Quote Link to comment Share on other sites More sharing options...
boonman Posted October 20, 2003 Report Share Posted October 20, 2003 You have the right one!! I ran a wire directly from that wire off the stator to a toggle switch. From there, i split it off to my lights, (Hella 500 lights) and I grounded the lights ground wires to the frame.... Worked like a champ... Quote Link to comment Share on other sites More sharing options...
sand_demon Posted October 20, 2003 Author Report Share Posted October 20, 2003 So I don't need the black one from the stator just the yellow one and ground it to the frame? And I don't need any fuse or regulator? Thanx Sorry for so many questions I just wanna get it right and not burn anything. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted October 20, 2003 Report Share Posted October 20, 2003 So your eliminating your stock lights or you will have both? If both, just unplug the low beam from your stock lights and use that plug for your lazer stars. That way you can toggle back and fourth, Otherwise you can use either wire. If your still confused give ricky stator a call and Im suer he can tell you EXACTLY what the best thing to do is. Quote Link to comment Share on other sites More sharing options...
boonman Posted October 20, 2003 Report Share Posted October 20, 2003 I didn't use a fuse but I am stupid when it comes to things like that. I would be using a 15 amp fuse. at a full 200 watts, you will draw 16.6 amps at 12 volts. But the shee puts out closer to 14 which would be about 14 amps..... And yes, clarify if you want the stock lights and the new ones, or just the new ones...... And I believe I just used the yellow wire.... Quote Link to comment Share on other sites More sharing options...
