Need clutch setup recomendation
I'm building a 4mm 421 serval and need to decide on a clutch setup. This will be mostly for trail riding so easy clutch pull and reliability are the biggest concerns.
There are a lot of different lockups out there now from last time I was looking at them so I don't know what the best setup would be. I would not mind modifying my stock cover if needed.
I don't want too heavy of springs because after 6 hours of trail riding with my current setup (all heavy springs) is just too much.
I run the whole direct drive setup. Lockup and 1 piece new cast cover. I like it and would do it all over again. I also just run 6 oem springs. That way I have a light clutch lever. It is a lot stiffer when the rpms are up but I usually dont use the clutch much unless I need to feather it.
Billit basket, pancake bearing, slingshot in stock cover, stock springs, fast or driveline clutch pack. It'll get ya hooked up, yet be soft enough to ride all day. I dig the sling shots for trails because they work to keep the motor moving with the extra inertia from mass. Works like the weighted flywheels do for the GNCC guys.
I've got good frictions and steels so I will run them. I'd like to run all stock springs with the slingshot lockup if it would hold the power well. I'm not sure if a pancake bearing is needed. I've always been aware of the ball welding and never has. The banshee will probably no longer be used for the rough trails since I have a high HP 4x4.
  • 2 weeks later...
