banshee jetting
shee wont start real good wont idle when cold but when warm idles a lil bit has no powerband has 25 pilot 290 main has athena big bore kit 392 k&n filter lid with snorkel removed stock reeds stock carbs tors eliminator toomey t5 110octane amsoil yellow cap 2 stroke oil 32.1 mix around 700 elavation need help
Start with the east stuff. Hard to start? Make sure choke tube is connected to both carbs with no spit ends,clean carbs. check plugs and check caps and plugs for fire. No power? this could be a lot of things. Electrical,compression,reeds, gas flow
I had it runnin just fine i got hurt couldnt work on it cus it wouldnt downshift so i let a friend fix that i get it back it wont run like it did useto start first kick before it was also summer then now its like 30 out an i switched from fmf to toomey an i put a new stator on it also last week An also put new plugs in it didnt help
I cleaned carbs an put needle on 4th clip an its idlin a lil bit still takes a a few kicks to start an i adjust the throttle cables on top carb to bring idle up alil cus idle screws dont work anymore i have a 27,5 pilot ordered just waitin on that anythin else u think of that could b wrong
Well figured out the powerband deal the stator i put on there somthing isnt right with it its an oem adjustable timing deal i put my old one back on it ran good just gotta figure out the jetting now an thanks for the help guys an ill have to sand that shit down so itll go in all the way but thanks again an what needle position would b the best u think
