mhoksch Posted March 6, 2013 Report Share Posted March 6, 2013 I have a bad intermittent miss in the high rpms, I'm going to try replacing my coil to start with. Are there any good aftermarket coils or should I just get oem? Sent from my PB99400 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 6, 2013 Report Share Posted March 6, 2013 Have you changed plugs? Quote Link to comment Share on other sites More sharing options...
mhoksch Posted March 6, 2013 Author Report Share Posted March 6, 2013 Ya, fresh plugs and new flywheel. Trying to get in touch with Gary to get a new stator too. It's a new motor, pipes and carbs. Runs good down low but had trouble getting into the pipes and misses bad once it does Sent from my PB99400 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 6, 2013 Report Share Posted March 6, 2013 Carbs, jetting, temp, elevation? Are your grounds good? Quote Link to comment Share on other sites More sharing options...
mhoksch Posted March 6, 2013 Author Report Share Posted March 6, 2013 Pwk 35's 50/155 4th clip 20-30 degrees 900ft. If it was ground I wouldn't run at all right? Sent from my PB99400 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
BeeCanBanshee Posted March 6, 2013 Report Share Posted March 6, 2013 Test it first takes 5min. That way your not wasting money. Test your caps and wires as well. It dorsnt take much time to test your electricals. And like loco said check grounds the coil has to have good contact with the frame, the mounts on the coil act as a ground Quote Link to comment Share on other sites More sharing options...
mhoksch Posted March 6, 2013 Author Report Share Posted March 6, 2013 Ya, I jsut figured since I was replacing everything else I might as well do the whole electrical system too. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 6, 2013 Report Share Posted March 6, 2013 That main sounds pretty small to me considering the temps. What motor is this? I think you should put 162 in there and try that first. Quote Link to comment Share on other sites More sharing options...
mhoksch Posted March 6, 2013 Author Report Share Posted March 6, 2013 It's a 370LR, dune port, +4 timing, VF2, PD coolhead (not sure on dome size) Shearer SB IF, 35 PWK's, Just got the motor back from Redline and put it in. Cam sent me a 150 and 155 for mains. I'm assuming it's electrical and not jetting because when I pulled one plug out it was wet, I figured that meant my issue was with the ignition. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 6, 2013 Report Share Posted March 6, 2013 Not necessarily. Does it have good spark when you check it? Quote Link to comment Share on other sites More sharing options...
mhoksch Posted March 6, 2013 Author Report Share Posted March 6, 2013 Spark looks good when I check, but low rpms are fine. It's only when I hit high rpms that I have problems Sent from my PB99400 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 6, 2013 Report Share Posted March 6, 2013 Change the jets. It's your job to tune the bike. Install 162 mains and see what happens. Quote Link to comment Share on other sites More sharing options...
mhoksch Posted March 6, 2013 Author Report Share Posted March 6, 2013 Ok, I'll try the jets when I get home from work tonight. Do you think A 165 might work? Only asking because I have 165's sitting there but would have to drive 45min to get some 162's Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted March 6, 2013 Report Share Posted March 6, 2013 If you have a ricky or RM stator, that's exactly the symptoms they cause... Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 6, 2013 Report Share Posted March 6, 2013 Ok, I'll try the jets when I get home from work tonight. Do you think A 165 might work? Only asking because I have 165's sitting there but would have to drive 45min to get some 162's Yes, 165 mains will work. If anything they may just be a little rich. Yea, what brand of stator? Quote Link to comment Share on other sites More sharing options...
