shift shaft seal
Yep, take a small pic or really small sharpened screwdriver and tap it into the face of the seal from the side and then just pry it out. Be careful not to scar the shaft or the case. They come out really easy.
This is how I did mine worked great.
No. You may be able to screw a small screw into the seal so you can pull it out.
Make sure the bike is tipped up or you'll lose your oil.
Loco way work good too. I have not used it on the shift seal but have use this trick on car before.
