JAGeSage Posted March 6, 2013 Report Share Posted March 6, 2013 Well, quad ran fine yesterday. Went out to start today, no spark. Tested my stator, my ign coil, my pickup coil, switched out cdi and coil, nothing worked out there for me. key switch isnt the issue. Known for a fact through the tester. Kinda at a stand still. Stator is oem, and tested perfect. So not quite sure where else to go. Any suggestions would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 6, 2013 Report Share Posted March 6, 2013 check your wiring for any melted through spots that are grounding any wires? Quote Link to comment Share on other sites More sharing options...
JAGeSage Posted March 6, 2013 Author Report Share Posted March 6, 2013 Already done, harness looks perfect, gotta go retape it. Was thinking maybe not getting a good Frame to motor ground? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 6, 2013 Report Share Posted March 6, 2013 that can definitely be it.......blowit (Brandon from mull engineering) just did a write up a couple of days ago about running a separate grounding strap from the motor to the frame. He has seen bikes do the no start issue due to bad grounds and he seems to really like the grounding straps. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 6, 2013 Report Share Posted March 6, 2013 Still have TORS? Thumb switch sticking?, might try unplugging it. You did test the key switch as if the wires are connected to run? just spit balling here, I did have an older bike that the thumb switch wouldn't shut a bike off. Quote Link to comment Share on other sites More sharing options...
JAGeSage Posted March 6, 2013 Author Report Share Posted March 6, 2013 Thumb switch was bypassed has twist throttle tors removed, Figured it out, was the frame to motor ground, gonna look up Brandon's post and run the ground and throw it back together. Thanks for letting me bounce the ideas around, also thanks for the help. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 6, 2013 Report Share Posted March 6, 2013 Let me know what you find out, I personally don't think the frame needs to be grounded if all your black wires are intact. And, with the chain,clutch cable,and most aftermarket exhaust, how it wouldn't be grounded anyway. Because is sure isn't meant to make contact through the mounts. But I'm going to do some testing on that myself. Quote Link to comment Share on other sites More sharing options...
JAGeSage Posted March 6, 2013 Author Report Share Posted March 6, 2013 I solved the problem taking a peice of 14 g fencing wire, wrapping it through the frame and touching it to the cylinder, went from no spark to spark. Honestly didnt think it would cause the problem myself, but with bushings and bearings and whatnot I can see why swing arm chain and sprockets would stop the grounding process. Quote Link to comment Share on other sites More sharing options...
blowit Posted March 7, 2013 Report Share Posted March 7, 2013 Outstanding There are actually a couple great points on both sides of the fence here. The OP was able to successfully repair the said bike with proper grounding. Hoppedup above has indicated the frame does not need grounded. Both are actually right. Technically the engine has a ground wire, which is black, is 18ga IIRC, and is mounted on one of the stator bolts. however, that is a pathetic ground and grounds should NEVER go through a socket termination IMO due to corrosion /etc, and the voltage regulator grounds grounds directly to chassis. These are reasons that the chassis really should have a better ground reference. If you look at a more modern battery equipt bike, many will have a couple wires coming off the battery negative. One goes to the frame, the other to the motor. Yes, technically, the Banshee is grounded effectively because most anyone that has problems owns older or custom Banshees, however, the fact that it is prevalent enough to keep showing up says it ain't good enough. If you refer back to my post on this. a simple dedicated replacement of the entire grounding circuit wiring with bigger wire going right to the motor and frame is preferred. I remember people years ago being shocked by their own bikes due to potential (remember that word?) differences from frame and engine. That is what happens. I guess I should throw safety in there too that grounding the chassis will also keep you from getting zapped! lol EDIT: I wanted to expand on what I posted previously so as not to misdirect. I think I sort of tried to incorporate other ATVs and the Banshee. The Banshee does have a ground, otherwise the bike would not run. However, there is no dedicated ground from engine to chassis other than contact through the engine mounts, which is never advised or ideal. Simply running a ground from engine to chassis can both reduce down time, and protect yourself and electrical components in the chassis. many things ground to chassis ground and it is just not a good idea. Copper has roughly 50x more electrical conductivity than steel. Brandon Mull Engineering 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 7, 2013 Report Share Posted March 7, 2013 I posted these in another thread. Quote Link to comment Share on other sites More sharing options...
JAGeSage Posted March 7, 2013 Author Report Share Posted March 7, 2013 Definitely a useful idea, I just tapped into my frame and mounted onto a bolt. I like the shock mount better. Going to relocate. Gotta pull the motor and clean everything first. Doesnt look like its been done since bike was first bought. Thank you all for the help. Quote Link to comment Share on other sites More sharing options...
JAGeSage Posted March 7, 2013 Author Report Share Posted March 7, 2013 Well, turns out my problem isnt solved. Quit on me again. i dont know what the issue could be. Stator is good, coils are good, Swapped out and checked with others. swapped out everything I could think of. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 8, 2013 Report Share Posted March 8, 2013 make sure that wire actually has a good contact......and try your method of touching a wire from frame to motor.....see what happens..... Quote Link to comment Share on other sites More sharing options...
