Julito96 Posted March 4, 2013 Report Share Posted March 4, 2013 I see others posts with the same issue but no body write a clear measure to check my frame. My problem is that i already powder coat the frame and when i start to put the bike together i realize that the fuel tank doesnt fit in place. I need to solve this problem without damage the pc. Please if somebody know a way to do that i will apreciate. ps. sorry for my english, im from puerto rico and im trying to do my best. Quote Link to comment Share on other sites More sharing options...
erickson483 Posted March 10, 2013 Report Share Posted March 10, 2013 The only real way to fix it is using a lot of force. It sucks, but if you use a lot of rags it's not too bad. I did it to mine even after it was painted. Here's what you do: 1. Secure the frame to the floor 2. Wrap the steering stem mount with a shirt. 3. Place a floor jack in the frame, and rest it on the crossbar by where the Swingarm bolts to. 4. Raise the floor jack and start bending back that bar. You'll need about a 12" section of 4x4 or something similar to make it long enough to reach. This does work, but way easier with an extra person or two to help out. Worst case scenario, some PC may crack but even if it does you'll never see it. It's going to be covered up. It still pisses you off if the PC cracks, but at least you will be the only one who knows it is there. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 10, 2013 Report Share Posted March 10, 2013 Use a bottle jack. It's not that hard to move it back. Quote Link to comment Share on other sites More sharing options...
Julito96 Posted March 18, 2013 Author Report Share Posted March 18, 2013 Thanks a lot folks!!! It helps me a lot. I need to find a measure to know how much it needs to push. But i got the half of the job. Thanks!!! Quote Link to comment Share on other sites More sharing options...
SpecialEd 05 Posted March 19, 2013 Report Share Posted March 19, 2013 Use a bottle jack. It's not that hard to move it back. Yeah, this is the best method. Like Tyler said, it's not that hard to move. Just place the jack on a piece of 2x4 sitting across the frame where the rear tank mounts bolt in. Then jack the hoop forwards from there. If the powdercoat is decent quality and you use some rags it should be ok. There was a thread on he where somebody was asking the measurements but I can't find it. Maybe someone with a virgin frame can help? I think I jacked mine a bit too far forwards but only by a bit under 1/4". Quote Link to comment Share on other sites More sharing options...
icytea132 Posted March 20, 2013 Report Share Posted March 20, 2013 Can someone post pictures of a bent one and. Non bent one.. Mine looks pushed forward but idk I it's bent because I bought another frame and it's the same way Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted March 20, 2013 Report Share Posted March 20, 2013 Measure it....top to bottom. Quote Link to comment Share on other sites More sharing options...
icytea132 Posted March 20, 2013 Report Share Posted March 20, 2013 Ah sorry I think I'm thinking about the piece that looks pushed forward down where the bearing goes Quote Link to comment Share on other sites More sharing options...
SpecialEd 05 Posted March 21, 2013 Report Share Posted March 21, 2013 Oh, you're talking about the steering stop at the bottom of the steering stem? That bending forwar is very common from the constant hammering of full lock. Mine was bent forward about 1/4" at the top. So I hammered it back, ground out the crack and welded then added some gussets for strength. I did this before powdercoating though. Quote Link to comment Share on other sites More sharing options...
icytea132 Posted March 21, 2013 Report Share Posted March 21, 2013 Yup.. Mines bent.. Quote Link to comment Share on other sites More sharing options...
Julito96 Posted March 22, 2013 Author Report Share Posted March 22, 2013 I check the entire forum looking for the measures that i see somewhere. But no good results at all. Please if somebody see it or know a good reference measure to check the stem mount please post it. Thanks Quote Link to comment Share on other sites More sharing options...
