Jetting help PLEASE
Hey guy, Put a new set of  28 pwk's on the shee today and just cant figure which way to go......
Bike starrts fine and idles a little high....Tap the thottle and it idles down almost to stall then idles up again
Thats just one issue
NEXT
When taken for a test ride under full throttle it feels like its hitting a rev limiter and the topend is flat....
while testing i noticed that when given 1/2 to 3/4 throttle and held there, no WOT...it ran like a raped ape.....
Heres the setup
stock cyl stock stroke drag port
CPI inframes
VF3
UNI foam pods
+4 timing
Coolhead with 18cc domes(using sunoco supreme blue)
28mm pwk
165m
52p
n68 needle on middle clip
1 turn out on air screw
Im on long island so im at sea level and tuning for about 35-50 degrees as of now
Ok did the plug chop today... Trying to post pics but I got to where I feel it's right on or atleast close.....
155m
48p
Needle second from top
BUT.... Still having an issues with the idle....
I've did the carb cleaner trrick and no leaks anywhere... It will start and idle high about 1/8 throttle and when I just blip the throttle it idles down almost to stalling then creeps back to 1/8 throttle.... Sometimes it stalls as well when I blip it.... Also when slowing from riding speed it seems to stay at a high idle......
More pilot?
Drop needle?
I'm kinda stumped..
