guns4children Posted March 2, 2013 Report Share Posted March 2, 2013 it has 350 twin on the side that means its 350 on each side so that makes it a 700 right?? Quote Link to comment Share on other sites More sharing options...
general_lee_banshee Posted March 2, 2013 Report Share Posted March 2, 2013 Yup your right Quote Link to comment Share on other sites More sharing options...
oldskool Posted March 3, 2013 Report Share Posted March 3, 2013 Take one side off and you will good Quote Link to comment Share on other sites More sharing options...
guns4children Posted March 3, 2013 Author Report Share Posted March 3, 2013 Take one side off and you will good thats stupid you cant do that Quote Link to comment Share on other sites More sharing options...
Nightmare Posted March 3, 2013 Report Share Posted March 3, 2013 Lmao Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
James_21 Posted March 3, 2013 Report Share Posted March 3, 2013 You can take one side off, just break the connecting rod off and jb weld a plate over it and you will be all set 1 Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted March 3, 2013 Report Share Posted March 3, 2013 And if you bore it 20 over its a 740 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 3, 2013 Report Share Posted March 3, 2013 I suggest adding the .050 base plate. It will make the cylinders way taller and then you will have hella displacement. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted March 3, 2013 Report Share Posted March 3, 2013 Ooooo Jazoooooo Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
general_lee_banshee Posted March 3, 2013 Report Share Posted March 3, 2013 You can take one side off, just break the connecting rod off and jb weld a plate over it and you will be all set . Yup^^ what he says Quote Link to comment Share on other sites More sharing options...
foxrider603 Posted March 3, 2013 Report Share Posted March 3, 2013 Maybe even wire up a blow dryer in your air box and it will work as a turbo 1 Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted March 3, 2013 Report Share Posted March 3, 2013 Maybe even wire up a blow dryer in your air box and it will work as a turbo a shop vac will work better, it has a little more power Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted March 3, 2013 Report Share Posted March 3, 2013 So my 421 serval is actually an 842??? If so that is bad ass!!! Thanks for mentioning this to us guns, I can't believe everyone has overlooked this fact for sooo many years!!! U da man Quote Link to comment Share on other sites More sharing options...
2strokeshees Posted March 3, 2013 Report Share Posted March 3, 2013 Twin = 2 (usually) 350 x 2 = 700 Yes you are absolutely correct. 2 Quote Link to comment Share on other sites More sharing options...
quadpro26 Posted March 3, 2013 Report Share Posted March 3, 2013 only if you added the high performance powerbands 1 Quote Link to comment Share on other sites More sharing options...
